Old 09-25-2013, 07:47 AM   #1
pdvasquez's Avatar
2007 25' Safari SS SE
Hico , Texas
LED lights
We have 2007 safari ..Thinking of switching out the lightbulbs to led lightbulbs. Has anyone tackled this task? Worth the price and effort. Longer battery life??
Happy Trails,
Philip & Luci
Lazy Dude Ranch
Hico Texas
pdvasquez is offline   Reply With Quote
Old 09-25-2013, 07:50 AM   #2
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
My 2011 Flying Cloud came with LED's,,, Majorly improvement
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 09-25-2013, 08:25 AM   #3
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
You will definitely have longer battery life, depending on how many lights you normally use at any given time, because your amp draw will be so much less ....and they put out much less heat. Whether you like the look of LEDs (some complain that they produce an un-natural light spectrum)...is the question. And of course, it will be spendy to replace everything....but well worth the investment, IMHO.
arktos55343 is offline   Reply With Quote
Old 09-25-2013, 08:31 AM   #4
pdvasquez's Avatar
Hico , Texas
Thank you for your post. We are planning our first boondocking trip and thought it might help us with better battery life.
Happy Trails,
Philip & Luci
Lazy Dude Ranch
Hico Texas
Old 09-25-2013, 08:37 AM   #5
ginsun88's Avatar
2007 25' International CCD
San Diego , California
Led4rv
We bought from Dan at LED4RV as he was recommended highly by these forums.
Dan is very knowledgeable and takes the time to explain everything, LEDs 4, Recreational Vehicles.
ginsun88 is offline   Reply With Quote
Old 09-25-2013, 08:47 AM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I've done a lot of work on this. There are lots of people selling LED lights. Vintage Trailer Supply has some good ones. However, I have found really good prices on lights from Deal Extreme.com There's so much there that it's hard to navigate. I found a set of warm white at 4500K that were perfect. The Kelvin scale is weird with LED lights. You have to order samples as some of the lights look a little blue, some pink, and some green. I've only found this one bulb that was as close to perfect as I could get, and it was hard to tell the difference. I ordered a bunch to replace all the bulbs in my 64. 115650-27WN 5W 300lm 4500K 27-5050 SMD LED Warm White Light Car Turn Signals Lamp (2 PCS)
Led lights will heat up though, but not as much as incandescent bulbs. Also, they are very polarity sensitive. If your socket was wired for regular bulbs, they may or may not have been as sensitive to the polarity, but for LED bulbs it's critical. If you find a socket doesn't work, reverse the wires.
You can expect a drop in heat, and a drop in DC usage. You may also have fewer shadows at the LED bulbs have multiple little lights on a single bulb base. There are also some fun dramatic options like multi color, and wired and wireless dimmers. Since the trailer's system is 12V, you have lots of options.
robwok is offline   Reply With Quote
Old 09-25-2013, 09:50 AM   #7
Roblin , MB.
We also replaced original incandescent bulbs with Led's in our '74 International 31'. Dealt with Dan at LED4RV. Highly recommend his products and personal service.
We were able to retain our original fixtures. New Led strips plugged into the original bulb sockets. Cost some $$$ but well worth the expenditure.
nairnchyz is offline   Reply With Quote
Old 09-25-2013, 03:55 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Don't forget you don't have to change them all at once, if there are only 6 bulbs you use 90% of the time start with them.
Old 09-25-2013, 05:13 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We put LEDS in all of our fixtures except the 9 recessed ceiling halogens. So when boondocking we have enough LED light but can still go brighter if we want when plugged in. Works well for us.
And they do let your battery last noticeably longer.
Wayne&Sam is online now   Reply With Quote
Old 09-25-2013, 07:29 PM   #10
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I replaced all of mine ... the standard 1156 incandescent bulbs that were in the fixtures from the factory drew 2.1 amps each. I put in a wide variety of new LED bulbs, and they drew various amounts, ranging from 36 miilliamps to 190 milliamps. Even the brightest of these are not quite as bright as the originals, but are pretty close, so I have those in all of my ceiling fixtures. Since they draw less than 1/10 of what the originals did, I figure I'm saving quite a bit of battery life this way. And they are WAY cooler, which is nice in summer ... in winter not so much. Got mine from LED Lights, Bulbs & LED Lighting Accessories - SUPER BRIGHT LEDS ... the largest ones I'm using are this model:
1156 LED Bulb - Single Intensity 9 High Power SMD LED Lamp | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
I can't say whether they would fit your fixtures, though, so don't order a bunch without measuring first! They're not cheap, but after four years, I've yet to have one burn out, and they're plenty of light for me to read by, tie trout flies, etc.
AirsDream is offline   Reply With Quote
Old 09-30-2013, 10:05 PM   #11
LFC
Memphis , Tennessee
I replaced all mine with LED bulbs even the fridge and vent a hood. One thing to consider is how many lumen they are rated at. Mine were all single pole bulbs with the exception of the fridge http://www.m4products.com/42mm-211-b...-bright-white/ and vent a hood http://www.m4products.com/5050-smd-c...se-10-30-volt/
I used the "cool white" 340 lumens Cool Bright White 1141 1156 Retrofit LED Light and put the Elite series 640 lumens Elite Series Retrofit Bulb where I thought I needed more light. I put one of the Elite series in my porch light and man is it bright. They do sell cheaper bulbs that aren't near as bright.
The other thing I really like is now I've got bright white lighting instead of dim yellow lighting.
This company is based in California and I received both my orders in 3 days.
LFC is offline   Reply With Quote
Old 09-30-2013, 11:16 PM   #12
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Like everyone has said above, switching to LEDs will extend your battery life between charges. This makes boondocking much easier. As was also mentioned, the LEDs put out a lot less heat than the stock halogen bulbs, which can be important during the hot summer months. We got ours from Dan at LED4RV.com. Dan was very helpful and we received our orders very quickly and he gave us great customer service. I highly recommend him.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 10-01-2013, 02:55 PM   #13
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
I also replaced all my lights with LED and they draw about 1/10 of what the regular incandescent bulbs did. I priced the conversion using one of the vendors listed here and the price came out to be more than $300, I did a little research and was able to buy quality lights directly from Hong Kong for a little more than $100 thru a seller on eBay. Keep in mind that those bulbs you may be buying from a US retailer are most certainly also made in China.
There has been a few discussions on this in the past few months on the forums here, so you may want to search for that thread.
Having said all that, I would highly recommend making the switch to LEDs.
Good luck,
-J
jpons is offline   Reply With Quote
Old 10-01-2013, 04:27 PM   #14
2005 19' Safari
GLENDALE , AZ
I recently replaced all incandescent bulbs in our 2005 19-foot Bambi for around $100 ($4.99 each). Vendor was in Florida; $5 shipping charge. Received order in Phoenix on third day after placing order. See details, on link below:
http://www.airforums.com/forums/f312...ml#post1355364
Help to Install new teardrop LED marker lights Air-Texas Lights - Interior & Exterior 19 03-21-2012 10:51 AM
Over-cabinet LED strip lights...YAY! vinnysca Lights - Interior & Exterior 9 01-26-2012 05:01 PM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
LED Interior lights Matt Kline Lights - Interior & Exterior 1 02-19-2011 05:31 PM
