09-25-2013, 07:47 AM
2007 25' Safari SS SE
Hico
LED lights
We have 2007 safari ..Thinking of switching out the lightbulbs to led lightbulbs. Has anyone tackled this task? Worth the price and effort. Longer battery life??
Happy Trails,
Philip & Luci
Lazy Dude Ranch
Hico Texas
09-25-2013, 07:50 AM
2011 23' FB Flying Cloud
Perry
My 2011 Flying Cloud came with LED's,,, Majorly improvement
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
09-25-2013, 08:25 AM
1972 25' Tradewind
Hopkins
You will definitely have longer battery life, depending on how many lights you normally use at any given time, because your amp draw will be so much less ....and they put out much less heat. Whether you like the look of LEDs (some complain that they produce an un-natural light spectrum)...is the question. And of course, it will be spendy to replace everything....but well worth the investment, IMHO.
09-25-2013, 08:31 AM
Hico
Thank you for your post. We are planning our first boondocking trip and thought it might help us with better battery life.
Happy Trails,
Philip & Luci
Lazy Dude Ranch
Hico Texas
09-25-2013, 08:37 AM
2007 25' International CCD
San Diego
Led4rv
We bought from Dan at LED4RV as he was recommended highly by these forums.
Dan is very knowledgeable and takes the time to explain everything, LEDs 4, Recreational Vehicles.
09-25-2013, 08:47 AM
1964 26' Overlander
Richmond
, Virginia
I've done a lot of work on this. There are lots of people selling LED lights. Vintage Trailer Supply has some good ones. However, I have found really good prices on lights from Deal Extreme.com There's so much there that it's hard to navigate. I found a set of warm white at 4500K that were perfect. The Kelvin scale is weird with LED lights. You have to order samples as some of the lights look a little blue, some pink, and some green. I've only found this one bulb that was as close to perfect as I could get, and it was hard to tell the difference. I ordered a bunch to replace all the bulbs in my 64. 115650-27WN 5W 300lm 4500K 27-5050 SMD LED Warm White Light Car Turn Signals Lamp (2 PCS)
Led lights will heat up though, but not as much as incandescent bulbs. Also, they are very polarity sensitive. If your socket was wired for regular bulbs, they may or may not have been as sensitive to the polarity, but for LED bulbs it's critical. If you find a socket doesn't work, reverse the wires.
You can expect a drop in heat, and a drop in DC usage. You may also have fewer shadows at the LED bulbs have multiple little lights on a single bulb base. There are also some fun dramatic options like multi color, and wired and wireless dimmers. Since the trailer's system is 12V, you have lots of options.
09-25-2013, 09:50 AM
Roblin
, MB.
We also replaced original incandescent bulbs with Led's in our '74 International 31'. Dealt with Dan at LED4RV. Highly recommend his products and personal service.
We were able to retain our original fixtures. New Led strips plugged into the original bulb sockets. Cost some $$$ but well worth the expenditure.
09-25-2013, 03:55 PM
1988 32' Excella
Robbinsville
, New Jersey
Don't forget you don't have to change them all at once, if there are only 6 bulbs you use 90% of the time start with them.
09-25-2013, 05:13 PM
2014 25' Flying Cloud
Cuddebackville
, New York
We put LEDS in all of our fixtures except the 9 recessed ceiling halogens. So when boondocking we have enough LED light but can still go brighter if we want when plugged in. Works well for us.
And they do let your battery last noticeably longer.
09-25-2013, 07:29 PM
1999 23' Safari
Perrysburg
, Ann Arbor
I replaced all of mine ... the standard 1156 incandescent bulbs that were in the fixtures from the factory drew 2.1 amps each. I put in a wide variety of new LED bulbs, and they drew various amounts, ranging from 36 miilliamps to 190 milliamps. Even the brightest of these are not quite as bright as the originals, but are pretty close, so I have those in all of my ceiling fixtures. Since they draw less than 1/10 of what the originals did, I figure I'm saving quite a bit of battery life this way. And they are WAY cooler, which is nice in summer ... in winter not so much. Got mine from LED Lights, Bulbs & LED Lighting Accessories - SUPER BRIGHT LEDS ... the largest ones I'm using are this model:
1156 LED Bulb - Single Intensity 9 High Power SMD LED Lamp | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
I can't say whether they would fit your fixtures, though, so don't order a bunch without measuring first! They're not cheap, but after four years, I've yet to have one burn out, and they're plenty of light for me to read by, tie trout flies, etc.
09-30-2013, 10:05 PM
Memphis
, Tennessee
I replaced all mine with LED bulbs even the fridge and vent a hood. One thing to consider is how many lumen they are rated at. Mine were all single pole bulbs with the exception of the fridge http://www.m4products.com/42mm-211-b...-bright-white/ and vent a hood http://www.m4products.com/5050-smd-c...se-10-30-volt/
I used the "cool white" 340 lumens Cool Bright White 1141 1156 Retrofit LED Light and put the Elite series 640 lumens Elite Series Retrofit Bulb where I thought I needed more light. I put one of the Elite series in my porch light and man is it bright. They do sell cheaper bulbs that aren't near as bright.
The other thing I really like is now I've got bright white lighting instead of dim yellow lighting.
This company is based in California and I received both my orders in 3 days.
09-30-2013, 11:16 PM
2009 27' FB International
Los Angeles
Like everyone has said above, switching to LEDs will extend your battery life between charges. This makes boondocking much easier. As was also mentioned, the LEDs put out a lot less heat than the stock halogen bulbs, which can be important during the hot summer months. We got ours from Dan at LED4RV.com. Dan was very helpful and we received our orders very quickly and he gave us great customer service. I highly recommend him.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
10-01-2013, 02:55 PM
2008 20' Safari SE
Bangor
, Maine
I also replaced all my lights with LED and they draw about 1/10 of what the regular incandescent bulbs did. I priced the conversion using one of the vendors listed here and the price came out to be more than $300, I did a little research and was able to buy quality lights directly from Hong Kong for a little more than $100 thru a seller on eBay. Keep in mind that those bulbs you may be buying from a US retailer are most certainly also made in China.
There has been a few discussions on this in the past few months on the forums here, so you may want to search for that thread.
Having said all that, I would highly recommend making the switch to LEDs.
Good luck,
-J
10-01-2013, 04:27 PM
2005 19' Safari
GLENDALE
, AZ
I recently replaced all incandescent bulbs in our 2005 19-foot Bambi for around $100 ($4.99 each). Vendor was in Florida; $5 shipping charge. Received order in Phoenix on third day after placing order. See details, on link below:
http://www.airforums.com/forums/f312...ml#post1355364
10-01-2013, 05:37 PM
2005 28' Safari S/O
Paradise
If you dry camp or boondock regularly, it is definitely worth the cost and effort. You will certainly notice your batteries holding their charge longer. If you camp mainly at RV parks with hookups, the necessity diminishes, unless you would like to reduce the interior heat build up that incandescent bulbs contribute to, or are concerned about the environment and want to decrease your carbon footprint.
Steve
"THE OLDER I GET, THE BETTER I WAS"
10-01-2013, 06:07 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Originally Posted by robwok
Isn't the 5 watt draw pretty high for LED?
Alan
10-01-2013, 07:33 PM
2004 30' Classic Slideout
Fenton
, Missouri
I remember purchasing a factory tail light conversion kit from Airstream. It was probably the best LED purchase I ever made since it made all the difference in the world for those following me. One of the things I noticed over time is how hard it is to see brake lights on trailers that are back lit by sunshine. I knew that once these became available, I had to make this improvement, primarily for safety reasons.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-02-2013, 06:25 AM
Memphis
, Tennessee
According to the lumen charts the cheaper bulbs aren't very bright.
10-02-2013, 08:48 PM
2006 19' Safari SE
Tucson
We have replaced all the halogen lights (and incandescent lights in the closest and bathroom) in our Safari SE. What a huge difference in battery life! You'll be so glad you did.
Once you have the LEDs (we also used Dan at LED4RV) it's a snap (literally) to replace those halogen bulbs in your recessed ceiling lights. Its a direct bulb replacement...you don't have to replace the fixture, just the bulbs...carefully pry open the innermost ring of the puck fixtures with a sharp knife being sure not to damage the surrounding aluminum skin in your SE. The glass lens is held in place by that ring so be sure not to let it fall an break. (Let the lens and fixture cool off before you try this....they get very hot from the halogens.) Replace the bulb and re-install the ring by snapping it into place. Voilá. The directional reading lights are easy, too, but take a different bulb — with connection prongs at the back rather than to the side.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
