Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-03-2008, 08:36 PM   #99
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 33
I have never used the Superbright LED G4 side pin bulb. They might have a wider angle emiter at 120 degrees beam pattern (listed). I can say that the IMTRA bulb has 8 emitters, a 60 or 90 degree beam pattern (I have the 90 degree model) and a 3 year warranty for just a few bucks more a bulb.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 09-19-2008, 09:57 AM   #100
ronstory
ronstory's Avatar
Profile:  1975 23' Safari
Portland , Oregon
I believe this is still on topic so here goes.
I'm going to put round 3"ish recessed lights into a 75 Safari. I'm looking at either putting in recessed dedicated LED lights (like found on sailorsams.com) or just opting for the standaed halogen variety since it give me the option of the 10W, 5W halogen bulbs plus the option to convert to LED.
I'm concerned that LED may not be bright enough and then I'll be stuck with limited options.
Ideas or observations for those folks that have bravely gone before?
Ron
ronstory is offline   Reply With Quote
Old 10-01-2008, 09:34 PM   #101
nangoff
nangoff's Avatar
Profile:  2004 28' International CCD
Franklin , Tennessee
I'd stick with 5 watt halogens
Having been down the road with G4 based lights, halogen, and led replacements, I'd stick with 5 watt halogens, and replace the 10 watt bulbs that came with your unit. Buy the 5 watters on e-bay. The LED's simply don't put out the light and you need to be very careful that they don't over heat and have good dc voltage (meaning a very good regulated supply). Gerry
nangoff is offline   Reply With Quote
Old 10-02-2008, 01:03 AM   #102
ronstory
ronstory's Avatar
Portland , Oregon
Gerry--
Thanks for the feedback. I'm still looking for lights and like the flexiblity of the good old halogen.
Ron
Old 10-02-2008, 04:11 AM   #103
Wayne&Sam
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
When I was on the factory tour last week I saw a box of LED light that be replacements for the halogens in a Safari. We asked about them, thinking they would be used in upcoming units. They said they tried them but they didn't provide enough light so they won't be using them.
I like the option of a lot of light when plugged in so I've gone with a few LED fixtures from West Marine. I use them when I'm concerned about saving power. They provide just enough light to make breakfast and not wake up Sam.
ccd, led
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 22 09-15-2007 08:58 PM
LED Camper Interior Lighting Number99 The Vendor's Forum 2 02-08-2007 03:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006 06:27 AM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 06:00 AM
