Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-01-2008, 01:29 PM   #71
wppii
wppii's Avatar
Profile:  2004 28' International CCD
East Nicolaus , California
I have not read through all of the posts for this thread but I converted to the G4-WHP6, bought from this site Super Bright LEDs - Bi-pin Base Bulbs. At the time all they had was cool white, looks like they have added warm white.They work grreat, easy to install.
wppii is offline   Reply With Quote
Old 06-01-2008, 02:36 PM   #72
nangoff
nangoff's Avatar
Franklin , Tennessee
Yeh, but how much darkness do you have now in return? They all seem to not put out as much light as a 5 or 10 watt halogen they replaced. I'm looking for someone to say that the unit they bought puts out more light than the halogen thgey replaced it with then I'll get interested again.
Gerry Goffinet
nangoff is offline   Reply With Quote
Old 06-01-2008, 02:48 PM   #73
wppii
wppii's Avatar
To nangoff,
can't deny, the cool white seem a bit dimmer. it does however extend the battery life for us. just a choice we work with.
Bill Porter
Old 06-01-2008, 03:12 PM   #74
nangoff
nangoff's Avatar
Bill,
I too have a CCD 28, 2004 vintage. Bought some G4 based multiple light led's for trial and have been disappointed. Some of the LED's have began to flicker; have you ever noticed the new traffic lights that are using LED arrays, a good number have some of the LED's burnt out. I'm skeptical of this industry yet; I ended up replacing all my 10 watt bulbs in my CCD with 5 watt. Very little visual effect and my power consumption was cut in half, literally...checked them out with an ammeter (am an electrical engineer)
Gerry
Old 06-01-2008, 03:54 PM   #75
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Almost there
Originally Posted by nangoff
Bill,
Gerry
Gerry and all,
Your overall perception is not unusual, there are significant issues that come with LED technology, as you mentioned, some of the traffic signals from the early days are failing (mostly green) due to various conditions. As for small lamp replacements typical in our Airstream, some of the products are just plain junk, some are OK, but none are currently available that will perform at the lower color teperatures to be considered "exact replacements".
The road map for LED efficacy (lumens per watt) improvement has shown tremendous positive jumps, mostly in the lab and in more technical applications. Unfortunatley, the smaller white light applications have not translated into commercially available product yet, and some of the probelms you have seen (flickering) is probably due to improper heat transfer that results in premature failure. Most LED "bulbs" lack sufficient heat transfer because they do not take into account a systems approach to the application.
Most of the manufacturers in LEDs have not put much effort in halogen replacements at the 5 to 15 watt range, except the MR-11 and MR-16 lamp types, which do not fit in our AS factory fixtures. I have been waiting for the right repalcement LED lamps that are quality and will perform as lower wattage replacements for the bi-pin type halogens. Some of the manufacturers are close. I believe when they hit approximately 100 lumens at 2 to 3 watts, and a color temperature between 2800k and 3500k, with an appropriately size heat transfer, most of you will be pleased with the performance. The reality today is that our application is just not large enough to satisfy the business equation for LED manufacturers, but the time is near...just hold on a bit.
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 06-01-2008, 04:32 PM   #76
Mexray
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
I am currently in the process of installing Dr LED, recessed 'spot' warm light LED units in the ceiling of our 78 Ambassador.
I'm installing them in conjunction with installing three new Fanstatic Fans from Vintage Trailer, the ones with the flat gray vent covers. It's easier to install all the wiring while the new vents are not yet installed.
I'm installing a total of 11 LED 'spots'...3 in the (mid) bedroom, 3 next to the sink/stove, and 5 forward above the gaucho. I'm installing them on 8 inch centers. They look good, and provide the AS interior with a 'modern' flair...IMHO
I tested the 'flood' version of Dr LED's recessed units, but found them to dim, and they have that blue/white harsh glare...the 'spot' version uses the 'warm' glow version LED's and the beam is more of a spot, but wide enough in a ceiling installation to provide a broad coverage at the couch level.
I'll post some pic's soon. Got the rear three mounted and they tested out great last night...I'm installing separate switches on the ceiling for each of the three 'areas' of lights.
I've also installed one of Dr LED's 'bulbs' into the outside Step light fixture. Previously I've converted all the rear tail/stop lights to LED units, and just finished replacing all the marker lights with LED units. I got my Dr LED units from West Marine...they have a good selection of LED stuff these days.
I haven't yet tackled the bedroom bunk lights, the two over the Kitchen sink, the round overhead light in the bathroom, or the two bathroom bulk head lights...those will be a challenge to change over, due to the amount of light output needed to be effective.
The Bunk reading lights can be done with new fixtures...but the other will be more challenging! Perhaps I can recess three 'spot' units to replace the large round original fixture that uses multiple bulbs...don't know yet.
Any successful conversions of these lights been down out in AS land?
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated
Mexray is online now   Reply With Quote
Old 06-01-2008, 04:42 PM   #77
nangoff
nangoff's Avatar
Time machine...what a strange handle.......past that I'm glad you straightforwardly addressed this subject....many have saidthe like the product, yup, I do too, but they don't go on to say what they don't like about the product....namely price and light output. I will hold on, until someone says eureka. Thanks, Gerry
Old 06-01-2008, 05:24 PM   #78
Wayne&Sam
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
I just bought a couple of 8-LED fixtures at West Marine for $20 each. I'll install them along side the existing incancesdents and see how the work.
Old 06-01-2008, 09:14 PM   #79
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
OK,
I did the full monte of my halogens to LEDs in my 19CCD......even went with red LEDs for the inner cabinet lights. They are the exact color temp (warm white) as the halogens and are about 75% (subjective evaluation) of the lumen output of the former halogens.
I like the reduced output, as I found the halogens to be very glaring. I am also getting a couple of 3 watt LED bulbs to test for reading light purposes.
On the plus side......I like the reduced output and the light 'color' is the same. I love the 'mood lighting' that the reds give me from behind the frosted doors of the upper cabinets......makes for a great nite light! And the best part....I can run my entire trailer on the amperage of just one 10 watt halogen.
On the negative..........COST.
I'll report back on the 3 watt model. I do have a 3 watt halogen flashlite, and it is superb! I'm expecting the same from the LED bulb.
BTW, I am now an authorized dealer for IMTRA Marine lighting products.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-01-2008, 09:23 PM   #80
utee94
Profile:  1963 26' Overlander
Originally Posted by lewster
OK,
So, how much DOES it cost for each replacement "bulb?"
Old 06-01-2008, 10:06 PM   #81
lewster
Commercial Vendor
lewster's Avatar
You've got mail!
AIR # 10325
Old 06-01-2008, 11:54 PM   #82
Mexray
Mexray's Avatar
Here's some pic's of the Dr LED units I mentioned in a few posts above...I've finished installing two sets, with only the units over the gaucho to go!
Here's the 3 lights in the mid twin bedroom...
A straight 'up' shot...
A shot of the 3 kitchen recessed LED's, with the bedroom in the background...
Mark Twain, updated
Old 06-02-2008, 12:03 PM   #83
nangoff
nangoff's Avatar
Who said you have to be particular? you own an Airstream don't you? They look very nice to me, class job.
Gerry
Old 06-17-2008, 10:30 PM   #84
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 35
I have switched to the IMTRA Marine G4 base LED lights for my primary over head light in my main salon. I HIGHLY recommend the IMTRA Marine units for retrofit into any of the CCD lights. There is even a rear pin LED that perfectly fits the reading spots lights.
Thanks to forum member Lewster, the trailer now sips power while still allowing a LOT of lights to be on. The main overheads are a warm white, and are FAR superior in light output and color to the warm whites I bought from Yachtlights over a year ago.
I also added four cool white lights for the eating area and for the kitchen counter downlights. Pics and comparisons to follow.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
ccd, led
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 22 09-15-2007 09:58 PM
LED Camper Interior Lighting Number99 The Vendor's Forum 2 02-08-2007 04:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006 07:27 AM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 07:00 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion -
