Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-22-2007, 07:33 PM   #57
whitelight
aluminauti
whitelight's Avatar
Profile:  Where we , Park it!
No more halogen was what we meant !
Hi Dianne - I checked with Dr LED (we met him at the Vancouver boat show - yes, there is a Dr LED!) as to why there is a red X over the 10W halogen bulb on their website.
Anyway, in his words "No more halogen was what we meant !"
So, if you have room for this G4 LED Magnum ring to replace the 10W halogen , then go for it!
whitelight is offline   Reply With Quote
Old 09-22-2007, 08:11 PM   #58
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Warm White G-4 Replacements
Hi Gang,
I just got a few G-4 direct replacement bulbs with 21 LEDs from SailorSams.com: 12 Volt LED Lights, 12 Volt Lights, Rope Lights, Small Microwaves, Marine Refrigerators, Coffee Makers, Electric Cooktops, Dock Cushions, Marine Hardware, Shrink Wrap for Boats, Boating Products and RV Accessories for overhead use, along with the same bulb in red for the overhead storage cabinets on the CCD. Expensive.....yes, but at a 10X reduction in amp draw and a light color equal to the halogens, they look great! I also found that the halogens were too bright anyway, so the warm white LEDs provide just the right amount of light for me.
Check them out if you're at the Fest in ABQ....................
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 09-22-2007, 08:58 PM   #59
whitelight
aluminauti
whitelight's Avatar
Imtra products-LED distributors
LED Replacement Bulbs - IMTRA Marine Products
For reference, Imtra is the distributor of the lights sold by several marine distributors, such as Sailor Sams. Here is the link to their LED products. This page also has a handy reference guide to determine replacements as well.
Apparently, Rekord Marine is coming out with a new line of soft white LED's. Also, Dr. LED is unveiling more LED lights at the Seattle Boat show in Jan 2008. One new style is going to be a G4 halogen replacement, 100 lumens, 2" in diameter, 1/3" thick.
We have two Dr. LED Saturn flush mount rings that will be installed in the galley of our 34 front kitchen. Will post pics when installed.
Old 09-23-2007, 09:33 AM   #60
BDandTTs
BDandTTs's Avatar
Profile:  2005 22' International CCD
Huntington , Vermont
Images: 37
Thanks for the inside information from Dr. LED, Whitelight. I did misunderstand his graphic. His lights might work especially well in vintage units. And thanks a lot for the link to IMTRA.
Based on Lew's recommendation for the 21 LED warm light, IMTRA's at $22 each sounds like our best choice as long as shipping charges are not outrageous. Hope to order on Monday.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 11-14-2007, 01:45 PM   #61
G-STREAM
69 Caravel
Profile:  1969 18' Caravel
Salmon Arm , BC
What do these LEDs do when the voltage drops below 12v? I put some socket style LEDs in my vintage lights and the minute the battery goes low I get zero output, atleast with the old style they just go dim.
G-STREAM is offline   Reply With Quote
Old 11-14-2007, 04:25 PM   #62
Ahab
Ahab's Avatar
Profile:  2008 22' Safari
Oracle , Arizona
We replaced all the incandescent bulbs in our old PU with LED's and now doing the same with our new A/S. I use the superbrightled.com products as they seem to be the most bang for the buck. They now have a warm rendition which costs more and I only ordered one to try out. We have no problem with the slight blue tint offered by the conventional 24 and 32 unit arrays. We boondock and dry camp alot so these are a must for us.
Ahab is offline   Reply With Quote
Old 11-14-2007, 05:01 PM   #63
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
You musta read my mind!
Thanks for bringing this thread back to life.
I finally burned through the replacement bulbs I bought 2 years ago and needed to order more - so this thread comes in mighty handy. No more paying $5 per bulb at Home Depot. Thanks.!
Paula (I just love the new smiley!)
Today is a gift. That's why they call it "the present"
Old 01-13-2008, 09:39 PM   #64
Motoman
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside , California
Has anyone tried the new higher wattage LEDS in the six LED configuration such as the G4-WHP6 White LED bulb on the superbrightleds.com site and compared them to the 21 LED style such as the ILG4-21L12V60W on the IMTRA web site IMTRA Marine Products
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 01-13-2008, 10:59 PM   #65
nangoff
nangoff's Avatar
Profile:  2004 28' International CCD
Franklin , Tennessee
I have yet to find any definitive lumens output of any of these LED arrays compared to classic halogen of 5 or 10 watts. Has anybody got a definitive lumen output of the LEDs?
Additionally, in a fair comparison the halogen light as mounted in its fixture will put out more light than a straight halogen bulb, so the light as mounted in its fixture would be the benchmark for a halogen bulb.
Also, is the comparison of lumens between light sources linear or exponential? Example, is a 10 lumen light source twice as bright as a 5 lumen source or is it 4 times as bright?
Thanks, Gerry
nangoff is offline   Reply With Quote
Old 01-13-2008, 11:15 PM   #66
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Be careful about Lumens. LEDs are not as efficient as the headlines would lead you to believe, but they seem much more efficient than incandescents because they emit their light in a fairly tight beam. I'm wondering that if a halogen and LED have the same Lumens, perhaps that means that the light on the subject is brighter for the LED because all of it is focused in that direction? On the other hand, the halogen's light is going off in all directions. Anyone know how the specs work?
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 01-13-2008, 11:26 PM   #67
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
tough question
Thanks, Gerry
Lumens are linear per instrument testing in an integrating sphere, however, the human eye has interesting characteristics that confuse perception of light sources and in many cases the perceived "intensity" of the light may in fact not be linear, usually becoming a percentage factor as opposed to a one to one ratio.
Keep in mind that visual acuity is also affected by color temperature and other optical effects in the transmission of light that also changes the perceived intensity.
Bottom line, even luminosity is not a fair value to judge the lamps you are looking at for replacement for halogens. Light manufacturers are just like truck manufacturers, sometimes they kind of fudge the numbers, usually by testing "golden samples" which are typically not the average lamp that they distribute.
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 01-14-2008, 12:10 AM   #68
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 35
Yep, that is pretty much what I am using in my galley over heads. You'll see my description of the lights if you head back a page. They are good and the light output and color is acceptable. The fit is a little tight in the stock light housing, and when assembled the lens may push the LED back and break the connection. Re-adjusting the pins usually helped.
However, I am having a progressing failure on one of the bulbs. I've lost roughly half of the array in one bulb.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 01-14-2008, 07:57 PM   #69
hshovic
hshovic's Avatar
Profile:  2007 25' Safari FB SE
Bozeman , Montana
Gone and did it: Boondocking, LED lighting, and batteries
Greetings,
Just purchased and installed:
* Sailor Sam's G4 replacements for the halogens
(# IMT-ILG4-21LED12VW; 12 volt, G4 Style, LED Bulb, WARM WHITE)
* Superbright's 67 replacement LED's for clearance bulbs (I decided against changing the fixtures, since the existing ones look ok.)
* Bought one Superbright 1141 for task lighting to try it out. (1156-PCB-WHP9 White LED Lamp $ 21.95 (each))
The LED's in the halogen fixtures are slightly less bright, but have a nice spectrum. See below for before and after. I replaced 8 of 11 so probably have reduced AH by 80%.
The one to replace the 1141 was not so good. Quite dim but warm white, (kind of a waste of $21.95), so I went with fluorescents from Thin Lite for the task lighting. Twice the light at 1/2 the amperage. Cool white, but meant for task lighting, not ambience lighting..
Thanks to Davidz71 for his help and advice on this.
Then got two Lifeline 6V batteries for a total of 300 AH (I had about 170 before)... and because of the new batteries I needed an upgrade of the converter (Parallax ) and an extreme battery box makeover. More on this later.
And will try them all out in March.
Name:	non led ceiling light.jpg
ID:	52524  Click image for larger version
Name:	led ceiling light.jpg
Hank
WBCCI 1489 AIR 20708
2007 Chevy Silverado 3/4 ton 4 x 4 gas (and wife Rhoda
of much less (or no) gas and weight)
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 01-15-2008, 11:16 AM   #70
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 153
Fluorescents are (generally) the most efficient Lumen producer.
I bookmarked this page a while ago when I was relighting the '78.
It appears as if this guy certainly knows his way around a lumen.
Don's Lighting Info Center!
I was really surprised that most fluorescents are more efficient than LED's.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
ccd, led
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 22 09-15-2007 09:58 PM
LED Camper Interior Lighting Number99 The Vendor's Forum 2 02-08-2007 04:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006
