Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-18-2008, 06:20 AM   #85
dufferin
dufferin's Avatar
Profile:  2007 28' International CCD
on the go , Canada
Images: 11
I really like the LED idea. The reduced output would be my major interest. I do not use the roof halo because I have then the feeling that I am in a stadium... WAAAY too bright. I never find a dimmer that could fit in place of the switches so LED would be the way to go.
What are your thought about the Kodiak model.
Like the idea of the colored one for the upper cabinets.
d
Originally Posted by lewster View Post
OK,
I did the full monte of my halogens to LEDs in my 19CCD......even went with red LEDs for the inner cabinet lights. They are the exact color temp (warm white) as the halogens and are about 75% (subjective evaluation) of the lumen output of the former halogens.
I like the reduced output, as I found the halogens to be very glaring. I am also getting a couple of 3 watt LED bulbs to test for reading light purposes.
On the plus side......I like the reduced output and the light 'color' is the same. I love the 'mood lighting' that the reds give me from behind the frosted doors of the upper cabinets......makes for a great nite light! And the best part....I can run my entire trailer on the amperage of just one 10 watt halogen.
On the negative..........COST.
I'll report back on the 3 watt model. I do have a 3 watt halogen flashlite, and it is superb! I'm expecting the same from the LED bulb.
BTW, I am now an authorized dealer for IMTRA Marine lighting products.
Pdt Canadian Atlantic U. - WBCCI # 6162 - AIR #8059
Attn : IBT
Here's what the free of speech is :
"I may not agree with your ideas but I will fight to death to let you express them"
Voltaire - (rough translation from french)
dufferin is offline   Reply With Quote
Old 06-18-2008, 09:34 AM   #86
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 35
Yes, I'd say that the IMTRA warm white units are about the equivalent to a 5 watt halogen, dimmer a slightly more yellow. The 27FB has no fewer than eight 10 watt light in the main salon plus two around the closet and shower area. 80 watts of light is enough to make you go blind, especially if all you wanted to do was read a magazine and have a little task lighting. The new output is perfect.
Colored lights would be cool in the upper cabinet, and I saw the result in Lewster's Bambi. Red is both fun a functional, making a great night light and saving your night vision.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 06-18-2008, 10:11 AM   #87
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
I did count once the halo in the 28', all of them, makes 38...
So the change will done from time to time... cause it then would be around $1350
Attn : IBT
Old 06-18-2008, 10:48 AM   #88
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
dufferin,
I think your calculator key must have been stuck when you figured the cost. The total price to replace 38 halogen bulbs with IMTRA LED replacements in white (warm or cool) would be $684. If you use some red or blue LEDs, the cost is reduced significantly!
PM me if you need more specific info.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-18-2008, 05:52 PM   #89
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
aren't they $35 each?
Attn : IBT
Old 06-18-2008, 06:24 PM   #90
Westfalia
Westfalia's Avatar
Images: 35
Nope, the IMTRA warm white lights retail for $22. Lewster can get better pricing than that.
Here is the link to the IMTRA LED lights: IMTRA Marine Products
Old 06-18-2008, 06:28 PM   #91
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
thanks haven't seen that I was looking at the all thing... bulb and mounting stuff.
Attn : IBT
Old 06-18-2008, 06:39 PM   #92
Westfalia
Westfalia's Avatar
Images: 35
These bulbs would be direct plug for your 28' International. Yes, if you were wanting an integrated light assembly for the other trailer or were looking for a different bulb, it would cost more.
Old 07-03-2008, 12:02 PM   #93
Westfalia
Westfalia's Avatar
Images: 35
Sorry that it has taken me so long to post these pics. We have camped for a long weekend since the new lights were installed, and we LOVE them. In fact I ordered a few more to fill in a gap and to get LEDs for the swivel reading lights over the bed.
This pic shows the original 10W halogen lights in the row on the left, with the warm white LEDs on the right. I'd say that the light is equivalent in light output to a 5W halogen with MUCH less glare. It brings the light level in the salon to a much more manageable level.
Old 07-03-2008, 12:04 PM   #94
Westfalia
Westfalia's Avatar
Images: 35
Pic of a single LED array over the fridge:
Old 07-03-2008, 12:09 PM   #95
Westfalia
Westfalia's Avatar
Images: 35
Here is a comparison shot of different lights in the overhead cabinet.
On the left, the stock 10 watt halogen, in the center a cool white LED from IMTRA, on the right a warm white LED from IMTRA.
We ended up putting the cool white lights in the under cabinet fixtures that are over the sink and over the dinette.
Old 07-03-2008, 03:13 PM   #96
rseagle
rseagle's Avatar
Profile:  2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Do you also use the G4 side entry for the swivel lights?
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
WBCCI# 1430
AIR# 4749
rseagle is offline   Reply With Quote
Old 07-03-2008, 05:15 PM   #97
Westfalia
Westfalia's Avatar
Images: 35
No, Imtra has a rear pin led array that does the job nicely. Lewster shipped my order to me with a few extra bulbs that he needed for another project and they were the rear pin g4 in red and warm white. I "borrowed" those lights for a few days to play and really liked them. The red was red. About what you'd expect from a red led. Red would be better in an overhead cabinet or a spot that you wanted to use to help save your night vision.
Old 07-03-2008, 07:23 PM   #98
Fenghuang
Fenghuang's Avatar
Profile:  2007 23' Safari SE
San Diego , California
Chris, Do you know how the Imtra products compare with the Super Bright products?
"The only ones among you who will be really happy are those who will have sought and found how to serve"
Albert Schweitzer
Fenghuang is offline   Reply With Quote
ccd, led
