We replaced all the incandescent bulbs in our old PU with LED's and now doing the same with our new A/S. I use the superbrightled.com products as they seem to be the most bang for the buck. They now have a warm rendition which costs more and I only ordered one to try out. We have no problem with the slight blue tint offered by the conventional 24 and 32 unit arrays. We boondock and dry camp alot so these are a must for us.
I finally burned through the replacement bulbs I bought 2 years ago and needed to order more - so this thread comes in mighty handy. No more paying $5 per bulb at Home Depot. Thanks.!
Paula (I just love the new smiley!)
Today is a gift. That's why they call it "the present"
Has anyone tried the new higher wattage LEDS in the six LED configuration such as the G4-WHP6 White LED bulb on the superbrightleds.com site and compared them to the 21 LED style such as the ILG4-21L12V60W on the IMTRA web site IMTRA Marine Products
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
Yep, that is pretty much what I am using in my galley over heads. You'll see my description of the lights if you head back a page. They are good and the light output and color is acceptable. The fit is a little tight in the stock light housing, and when assembled the lens may push the LED back and break the connection. Re-adjusting the pins usually helped.
However, I am having a progressing failure on one of the bulbs. I've lost roughly half of the array in one bulb.
__________________ Chris - Boerne, TX / Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas! 2008 Dodge Ram 2500 6.7 CTD Mega Cab 1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
I have yet to find any definitive lumens output of any of these LED arrays compared to classic halogen of 5 or 10 watts. Has anybody got a definitive lumen output of the LEDs?
Additionally, in a fair comparison the halogen light as mounted in its fixture will put out more light than a straight halogen bulb, so the light as mounted in its fixture would be the benchmark for a halogen bulb.
Also, is the comparison of lumens between light sources linear or exponential? Example, is a 10 lumen light source twice as bright as a 5 lumen source or is it 4 times as bright?
Be careful about Lumens. LEDs are not as efficient as the headlines would lead you to believe, but they seem much more efficient than incandescents because they emit their light in a fairly tight beam. I'm wondering that if a halogen and LED have the same Lumens, perhaps that means that the light on the subject is brighter for the LED because all of it is focused in that direction? On the other hand, the halogen's light is going off in all directions. Anyone know how the specs work?
Fluorescents are (generally) the most efficient Lumen producer.
I bookmarked this page a while ago when I was relighting the '78.
It appears as if this guy certainly knows his way around a lumen.
Thanks, Gerry
Lumens are linear per instrument testing in an integrating sphere, however, the human eye has interesting characteristics that confuse perception of light sources and in many cases the perceived "intensity" of the light may in fact not be linear, usually becoming a percentage factor as opposed to a one to one ratio.
Keep in mind that visual acuity is also affected by color temperature and other optical effects in the transmission of light that also changes the perceived intensity.
Bottom line, even luminosity is not a fair value to judge the lamps you are looking at for replacement for halogens. Light manufacturers are just like truck manufacturers, sometimes they kind of fudge the numbers, usually by testing "golden samples" which are typically not the average lamp that they distribute.
__________________ Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
I have not read through all of the posts for this thread but I converted to the G4-WHP6, bought from this site Super Bright LEDs - Bi-pin Base Bulbs. At the time all they had was cool white, looks like they have added warm white.They work grreat, easy to install.
Yeh, but how much darkness do you have now in return? They all seem to not put out as much light as a 5 or 10 watt halogen they replaced. I'm looking for someone to say that the unit they bought puts out more light than the halogen thgey replaced it with then I'll get interested again.
I too have a CCD 28, 2004 vintage. Bought some G4 based multiple light led's for trial and have been disappointed. Some of the LED's have began to flicker; have you ever noticed the new traffic lights that are using LED arrays, a good number have some of the LED's burnt out. I'm skeptical of this industry yet; I ended up replacing all my 10 watt bulbs in my CCD with 5 watt. Very little visual effect and my power consumption was cut in half, literally...checked them out with an ammeter (am an electrical engineer)
Gerry
Gerry and all,
Your overall perception is not unusual, there are significant issues that come with LED technology, as you mentioned, some of the traffic signals from the early days are failing (mostly green) due to various conditions. As for small lamp replacements typical in our Airstream, some of the products are just plain junk, some are OK, but none are currently available that will perform at the lower color teperatures to be considered "exact replacements".
The road map for LED efficacy (lumens per watt) improvement has shown tremendous positive jumps, mostly in the lab and in more technical applications. Unfortunatley, the smaller white light applications have not translated into commercially available product yet, and some of the probelms you have seen (flickering) is probably due to improper heat transfer that results in premature failure. Most LED "bulbs" lack sufficient heat transfer because they do not take into account a systems approach to the application.
Most of the manufacturers in LEDs have not put much effort in halogen replacements at the 5 to 15 watt range, except the MR-11 and MR-16 lamp types, which do not fit in our AS factory fixtures. I have been waiting for the right repalcement LED lamps that are quality and will perform as lower wattage replacements for the bi-pin type halogens. Some of the manufacturers are close. I believe when they hit approximately 100 lumens at 2 to 3 watts, and a color temperature between 2800k and 3500k, with an appropriately size heat transfer, most of you will be pleased with the performance. The reality today is that our application is just not large enough to satisfy the business equation for LED manufacturers, but the time is near...just hold on a bit.
I am currently in the process of installing Dr LED, recessed 'spot' warm light LED units in the ceiling of our 78 Ambassador.
I'm installing them in conjunction with installing three new Fanstatic Fans from Vintage Trailer, the ones with the flat gray vent covers. It's easier to install all the wiring while the new vents are not yet installed.
I'm installing a total of 11 LED 'spots'...3 in the (mid) bedroom, 3 next to the sink/stove, and 5 forward above the gaucho. I'm installing them on 8 inch centers. They look good, and provide the AS interior with a 'modern' flair...IMHO
I tested the 'flood' version of Dr LED's recessed units, but found them to dim, and they have that blue/white harsh glare...the 'spot' version uses the 'warm' glow version LED's and the beam is more of a spot, but wide enough in a ceiling installation to provide a broad coverage at the couch level.
I'll post some pic's soon. Got the rear three mounted and they tested out great last night...I'm installing separate switches on the ceiling for each of the three 'areas' of lights.
I've also installed one of Dr LED's 'bulbs' into the outside Step light fixture. Previously I've converted all the rear tail/stop lights to LED units, and just finished replacing all the marker lights with LED units. I got my Dr LED units from West Marine...they have a good selection of LED stuff these days.
I haven't yet tackled the bedroom bunk lights, the two over the Kitchen sink, the round overhead light in the bathroom, or the two bathroom bulk head lights...those will be a challenge to change over, due to the amount of light output needed to be effective.
The Bunk reading lights can be done with new fixtures...but the other will be more challenging! Perhaps I can recess three 'spot' units to replace the large round original fixture that uses multiple bulbs...don't know yet.
Any successful conversions of these lights been down out in AS land?
__________________ Let us not be too particular; it is better to have old secondhand Airstreams than none at all. Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
