Old 09-08-2016, 05:12 PM   #365
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
$17.99 for a 10 pack
Kemblkr is offline   Reply With Quote
Old 09-08-2016, 07:00 PM   #366
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have 2 reading lamps in the sleeping area. They are wall mounts at the head of the bed and have auto type bayonete mounts. Single pin on the twist mount. I have tried several types of LED bulbs and can't seem to get any to work. The original bulbs have a single contact at the bottom as do the LED replacements that fit the mount OK but simply don't work. The lamps have 2 arms with 1 bulb each and the switch allows either single bulb to be on as well as both together. I have changed everything else to LED's and they all seem to work great.
Still working on this when I think about it.
ThanX all
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-08-2016, 07:57 PM   #367
2007 22' International CCD
LED lighting retrofit for interior lights
Check that the +12 volts is where the LED wants it. Compare with a voltmeter.
If not, they won't light up at all. Probably needs to be + 12 on the single pin, ground on the big hollow part of the socket.
Regular bulbs don't care. Could easily be wired bassackwards.
KE4GNK/AE
Old 09-09-2016, 08:37 PM   #368
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
My LED's (almost all lights have been changed) are about 7 1/2 years old, all still work fine, and they cost a lot more then than they do now.
Gene
Gene is online now   Reply With Quote
Old 09-10-2016, 07:38 AM   #369
ReggieDaniel
1972 27' Overlander
charlotte , North Carolina
LED Lighting
Originally Posted by bhayden View Post
Glad to see this thread is still alive since I'm about ready to start in on reviving my Argosy. The Lightinbox.com domain is a French website that looks to be a content creator. I'm guessing it was supposed to point to Lightingbox.com from Canada.
Pictures pictures pictures !
My error, I told you the wrong site, it's "lightinginthebox.com". I left out a word.
ReggieDaniel is offline   Reply With Quote
Old 09-10-2016, 07:40 AM   #370
ReggieDaniel
1972 27' Overlander
Again, LED lighting
If I do this enough, I may get it right, dang it!
"lightinthebox.com" is correct because I went back and checked twice this time.
Light-in-the-box...say it to myself 100 times.
Old 09-12-2016, 06:29 AM   #371
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Thread alive
Yes, it is good to see folks are still into going the LED route.
Somewhere i think I may have posted that most of the LEDs I have used on trailers and a moho, are rated at 15v. This because often we will have 14.8v feeding them, but LEDs do not like to be over driven, at lest not in the early days. Thus the "safety" margin.
Also nice that the price is about 1/4 of what it was in the days I spent over $1,000 converting a moho....
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-15-2016, 11:23 PM   #372
Muscle Shoals , Alabama
Subscribing
Great read.
mschneid is offline   Reply With Quote
Old 12-17-2016, 11:43 AM   #373
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by 5cats View Post
So I'm finally getting around to doing some LED experiments on my SE -- but how do the CCD-style halogen ceiling fixtures open up to get the the G4 lamp?
I'm baffled. They seem springy, but I didn't want to pull too hard. I can only get them to pull away from the surface about 1/2" -- and I can't figure out how to access the bulb.
A little help??
thanks,
-jd.
We replaced all the halogen bulbs in our rig with LEDs... I am pretty sure we have the same fixtures as you have ... On ours, we do not have to remove the light fixture to change out the bulbs...the innermost silver ring around the lens pops off... First, turn the lights off and let the lenses cool ... the halogens put a LOT of heat out. Once cooled, use a sharp knife to get under the outer edge of that ring, being careful not to scratch anything or let the knife slip. As you pry it up, be careful not to drop the lens which sits inside that ring.
Good luck! You will be amazed at how much less of a draw the LEDs make on your batteries...
TB & Greg and Abbey Schnauzer
#3954
ccd, led, lighting
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 56 06-05-2011 10:06 AM
LED Camper Interior Lighting Number99 Commercial Listings 2 02-08-2007 03:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006 06:27 AM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 06:00 AM
