Old 02-04-2015, 02:51 PM   #351
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Replacing lights
If you contact Dan at LEDs 4, Recreational Vehicles he can assist you. This is a reliable source and he can offer some advice.
Contact Link:
http://led4rv.com/index.php?main_pag...sjnthi0hdpo027
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 02-06-2015, 03:55 PM   #352
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
On post 300, it was 2 1/2 years and my LED's from Superbright were still fine; now after almost 6 years, they are still good.
When this thread started, the OP lived in Colorado, but no more. I think he moved to Texas and I moved further west in Colorado.
Gene
Gene
Old 03-24-2015, 06:38 PM   #353
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Has anyone tried this LED upgrade to the stock light fixture in the 70's model Airstreams
LED strip light kit for 18x18 70 s Model SKU685 [K18x18] - $89.95 : LEDs 4, Recreational Vehicles
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-24-2015, 06:57 PM   #354
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
I just ordered these for under the bulkheads:
Amazon.com: Gold Stars F3528002 LED Dome Light Fixture Double 921 Wedge 2 X 150 LUM 12v Natural White (3): Automotive
And some of these to replace the bulbs in the light fixtures:
http://www.amazon.com/HOT-SYSTEM-tra...JV4K7SBQKAZBY4
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 03-12-2016, 09:09 AM   #355
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
I haven't tried that kit, but I did something similar to my '72. I took leftover warm white led strip lighting from our undercabinet light and stuck them on in a box around the edge of the light. I wired the strips to one position on the 3 way, and all the original bulb lights to the other position, that way I can have LED or bulb light or both. I thought it was dim at first, but when you switch to either or, the brightness is about the same. I bought a roll of warm white led strips from Amazon, and a bunch of clip on connectors, and I'm going to wire them in while I have all my fixtures down. I think I might do two rows of led around and ditch the bulbs altogether. I also bought some generic 21 led panels to try instead.
they were 1.99 each, so it couldn't hurt.
"Daddy when's the trailer going to be finished?"
Can of beans is offline   Reply With Quote
Old 06-12-2016, 08:29 AM   #356
ReggieDaniel
1972 27' Overlander
charlotte , North Carolina
LED lighting in early 70's AS
I replaced 30 incandescent bulbs in my '72 International with LED lights. Went to "Lightinbox.com" and did a search for trailer lighting and found every kind of LED imaginable. I got 30 lights (with shipping included) for $31.96. Took two weeks to get across the pond but was well worth the wait. Every one of them worked. Have since replaced all of the exterior lights as well.
ReggieDaniel is offline   Reply With Quote
Old 06-12-2016, 10:36 AM   #357
Missouri Valley , Iowa
adonh, in my '02 Classic I put the 2 LED replacement strips in all of my 12" Thin Lites. I could not get a season of use from the fluorescent bulbs or ballast in the bathroom or under-cabinet kitchen fixtures. The updates were about $40 / light. The light is so nice and bright now. And they are not dim when it's cold as the fluorescents were. I used bright white LED strips except over the couch and bed where I used warm white. I got my LEDs from LED4RV. Good service and product.
Dan
Farmer Dan is offline   Reply With Quote
Old 06-12-2016, 10:39 AM   #358
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Lightbulb
Glad to see this thread is still alive since I'm about ready to start in on reviving my Argosy. The Lightinbox.com domain is a French website that looks to be a content creator. I'm guessing it was supposed to point to Lightingbox.com from Canada.
Pictures pictures pictures !
bhayden is offline   Reply With Quote
Old 06-14-2016, 03:17 PM   #359
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I have replaced a few of the puck halogen bulbs with LED's. So far so good and now I'm ready to replace the ceiling puck lights. There are 8 of them in the kitchen and hallway and four in the bedroom.
For those who have already made the conversion I have a question. Would using the 12 diode LED replacement be too bright in the kitchen? I am planning on using the 9 diode LED for the bedroom? I don't think it's a major decision but thought I could benefit from someone saying 9 diode LED's were not bright enough or the 12's are too bright.
BTW I'm using the warm color LED's and I got them from LED4RV.com.
Thanks!
Old 06-15-2016, 06:04 AM   #360
1976 31' Sovereign
Springfield , South Carolina
I think the biggest thing you will see is reduction of heat given off by the conventional bulbs.
I am thinking of putting in a string of 5050 bulbs around trough above the curtains to give off indirect lighting from the ceiling.
Now I am looking for a good light to replace the entry light over the door.
Hummer is offline   Reply With Quote
Old 06-15-2016, 07:41 AM   #361
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
I bought the 9 diode warm LED's from LED4RV.com for the puck lights. We are happy with them. The light is sufficient for us.
If you go with the 12 diode you might consider installing a dimmer switch.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 06-15-2016, 11:32 AM   #362
Hans627's Avatar
I appreciate your input. I have the 12 diode LED's above the dinette and the countertop/sink. Mainly for having plenty of light on work surfaces. I was thinking the 9's would work for the ceiling lights and glad to hear some confirmation before purchasing so many of them.
Thanks!
Old 06-17-2016, 11:32 AM   #363
Master of Universe
Gene's Avatar
Hans, it isn't the number of diodes, but the lumens produced that will tell you how bright it is.
We changed to LED's many years ago now, around when this thread started and the OP still lived in Colorado. Just about every bulb was replaced (closet one, courtesy lights and step light were the only ones not done). They all still work fine and cost about 10 times more then. We got them from Superbright as they had the best LED's when there were a lot of bad ones on the market.
I'm wondering whether the Airstream OEM LED's are lasting or where they the cheap kinds?
Gene
Gene
Old 09-08-2016, 06:11 PM   #364
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
These worked great in my 2003
Name:	ImageUploadedByAirstream Forums1473376287.590942.jpg
Kemblkr is offline   Reply With Quote
ccd, led, lighting
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 56 06-05-2011 11:06 AM
LED Camper Interior Lighting Number99 Commercial Listings 2 02-08-2007 04:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006 07:27 AM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 07:00 AM
