Old 01-05-2010, 12:01 AM   #239
Dan@LED4RV's Avatar
Denton , North Carolina
Airstream has it now
Originally Posted by flmgrip View Post
how does the lightoutput/intesity of this led compare to the original 10watt bulb?
Airstream now has this light configured for the reading lights
Here it is in Warm White
Here it is in Bright White
Looks pretty good.
fix
Dan@LED4RV is offline   Reply With Quote
Old 01-05-2010, 05:10 AM   #240
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Opening the ceiling pucks
Having changed all thirty or so in my 09 Int, I found a curved carpet knife worked well to ease under the edge of the puck lens without scratching anything. It is easily pried out and removed. Another method I have used is a tongue depressor, sharpened, which can be wedged under the edge of the puck lens. The wood does not scratch for sure, but sometimes the sharp edge will not last long. Good luck.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-05-2010, 11:25 AM   #241
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
Question gettng into pucks
i see the glass lens,then a ring of chrome, then another ring of chrome. do you pry between the glass lens and first chrome ring from the center or between the two chrome rings?
"Open paddock 9!"
dsrtgrls is offline   Reply With Quote
Old 01-05-2010, 01:59 PM   #242
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Between the two chrome rings. They are easy to scratch. Either grow really long finger nails, or use a thin knife blade such as on any pen knife. Once the blade separates the 2 parts a little, I inserted a screwdriver to pop out the inner part.
Some LED bulbs do not have long enough pins. I took the whole thing apart to make it all work by unscrewing the reflector so I could push the pins in, leaving it unscrewed and putting it all back together.
Gene
Old 01-05-2010, 02:25 PM   #243
Fenghuang's Avatar
2007 23' Safari SE
San Diego , California
Here is the link that I was talking about. I had forgotten to add it.http://www.airforums.com/forums/f447...s-17392-8.html
Larry
1767 Spanish scribe:"Rash judgments are always accompanied by ignorance and absence of light." (Learn all the facts before making a judgment)
Fenghuang is offline   Reply With Quote
Old 01-05-2010, 04:05 PM   #244
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Has anyone found a source for the puck light fixtures? You can get 5 in a pack with 115-to-DC converter for about $35 at Home Depot, but I just want the pucks. There was a temporary good deal last year where you could get 6 for about $18, but that's long gone.
Zep
Old 01-05-2010, 05:02 PM   #245
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Rockler has 3 watt led light fixtures in their new catalog but do not show them on line. Spendy @ $46 apiece, and 1 watt at 26ea.
And Mcfeelys has some here
Puck Cabinet Lights, 2 W LED, Grass Cabinet Lights, Lighting - McFeely's
Kip
Old 01-06-2010, 07:05 AM   #246
dsrtgrls's Avatar
Clarkdale , Arizona
thanks msmoto, crawfordgene, and fenghuang for the great info on opening that clam of a puck light. as soon as the bulbs arrive from as i will attempt shucking the three. camp on
"Open paddock 9!"
Old 01-18-2010, 07:17 AM   #247
dsrtgrls's Avatar
Clarkdale , Arizona
my fingernails were out of the question to open the puck fitures. i was able to take info from you all and came up with a system that worked. they are tough little clams. i had some old plastic store cards (the credit card type things). i took a little dremel and sanded down the corner to taper it thin to wedge it between the rings. got space enough for a little nudge with a small slotted screw driver and bingo, with no scratches. the airstream led replacements,though expensive, fit and worked great. thanks to all on this project.
"Open paddock 9!"
Old 02-13-2010, 03:08 PM   #248
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
LED's
Just ordered replacements for some puck lights, bulbs (over dinette, kitchen sink, and bathroom) and reading spot lights. This is the source I used:
LEDs 4, Recreational Vehicles
Free shipping on orders over $30 (not hard to do!)
Will post on the results after installation.
-Jerry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 02-18-2010, 10:36 AM   #249
Buzzy4's Avatar
2007 25' Safari FB SE
Argyle , Texas
Source for LEDs
I haven't seen this source mentioned in the forums yet. I replaced all my interior G4 halogens with LEDs from here last year both overhead and the reading lamps as well. I also replaced the 12v bulbs in the bath and over the stove.
Replacement LED bulbs for your existing boat fixtures
I tried a couple of LED replacements from Airstream and found the ones from Marinebeam to be much brighter. They are a bit more expensive but worth the extra cost in my opinion.
Ed
Buzzy4 is offline   Reply With Quote
Old 02-18-2010, 11:46 AM   #250
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Zep
I may be "re-dunding" here but VTS has 12v pucks for $19 bucks each....
fotochop is offline   Reply With Quote
Old 02-19-2010, 04:29 AM   #251
Msmoto's Avatar
2007 25' Safari
Images: 135
The LED brightness question
Having converted every bulb in my 27 FB International to LED from Out of Doors Mart, the brightness is entirely adequate and I rarely have all of them on. Plus it appears the cost is about half of that on the marinebeam site. Those must be absolutely fanastic. But, I am about to turn traitor and go to a big class A motorhome so .... Sorry, full time in my Airstream just did not have enough room for me.
Old 02-19-2010, 06:38 PM   #252
Maniacal Engineer
barts's Avatar
Menlo Park , California
A more reasonable source for those LED replacement bulbs:
DealExtreme: LED Light Bulbs (Page 1)
Friends on other forums report they work very well:
LED Lighting, now a practical alternative - The Home Shop Machinist & Machinist's Workshop BBS
no cheap warm white yet, though.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
ccd, led, lighting
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 56 06-05-2011 10:06 AM
LED Camper Interior Lighting Number99 Commercial Listings 2 02-08-2007 03:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006 06:27 AM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 06:00 AM
