Old 12-03-2009, 07:29 PM   #211
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I used a #15 and #12 photo filter, that's medium orange and ligh yellow. Anything in that region seems fine, doesn't filter too much light and cools it down enough so it's not that harsh blue.
A red filter almost blocked the light completely.
I'm looking for some yellow or orange wrapping celophane, which is a lot less expensive per square inch than photo filters!
Zep
Old 12-03-2009, 09:36 PM   #212
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Might also consider adding some good old fashion red LEDs. That might balance the spectrum and if on a different circuit could be a very effective night light set-up.
bhayden is offline   Reply With Quote
Old 12-03-2009, 11:33 PM   #213
ranchmink's Avatar
1979 28' Airstream Excella 28
Bakersfield , California
I just ordered 20 warm white LED bulbs from a source in a vendor off shore. These are a replacement for the 1156 bulbs in older units. I doing this as a test to see if they work. I will keep you posted. I should have them in the next week or so. The units are shown in the photo below. I like the omni direction. I will post photos on how this works.
Chris Addington
Central California
1965 Tradewind Trailer
1979 Airstream Motor Home
ranchmink is offline   Reply With Quote
Old 12-05-2009, 08:33 AM   #214
Dan@LED4RV's Avatar
Denton , North Carolina
They call the AC DC
Originally Posted by rogerthat View Post
here's a far superior G4 LED.... warm white color temp, very pleasing to the eye. (not the blue-ish white like a typical white LED) I'm running them and really like them a lot.
The one in this picture (above) is straight off the side.
The one picture below sits a little better in the puck light.
Ckick here to see this chip.
Airstream's part number on this one is 15751W-09
www.LED4RV.com has free shipping on this light
fixer58
Dan@LED4RV is offline   Reply With Quote
Old 12-05-2009, 10:43 AM   #215
Edgewood , New Mexico
What's the lumen output of the light below?
I've found that anything using the typical 5mm LED is pretty pathetic for light output
2005 GMC CC 4x4 D/A
rogerthat is offline   Reply With Quote
Old 12-05-2009, 10:46 AM   #216
THe one I used from LEDTrailerLights.com - RV LED interior ceiling light 1141 1156 warm white
has a 252 lumen output, which is nearly identical to all the specs I found for an 1141 bulb - which was 255 lumens.
2005 GMC CC 4x4 D/A
Old 12-07-2009, 07:52 PM   #217
ranchmink's Avatar
Thank you, this looks much better than what I ordered. I will order a few to try them out, thanks again.
Chris Addington
Central California
Old 12-07-2009, 08:27 PM   #218
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
Do you prefer warm white to cool white?
Nick
____________
Nick & Lorraine
nynick52 is offline   Reply With Quote
Old 12-07-2009, 08:49 PM   #219
ranchmink's Avatar
I would prefer to get as close to incad as possible and with color temperature close.
Chris Addington
Central California
Old 12-07-2009, 11:40 PM   #220
Warm white is really the most desirable.... it's about the same color temp as incandescent.
A less expensive LED for the outside light, which is cool white, is this one:
http://www.ledtrailerlights.com/stt/...57.htm#1156WSD
2005 GMC CC 4x4 D/A
Old 12-08-2009, 11:07 AM   #221
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We got our LED's from different sources over two years and got warm white for all but one fixture (that one is low lumens for a night light). I can't tell the difference from incandescent or halogen. However, there are cheapo LED's on the market and their color rendition may not be as good as the ones I bought.
Gene
Old 12-09-2009, 05:53 AM   #222
Dan@LED4RV's Avatar
same light
LEDTrailerLights.com - 1157 and 1156 LED replacement bulb style
I think this is the same light for less.
Click here to see it.
They do great on freight too
fix
Old 12-16-2009, 08:12 PM   #223
similar, but far dimmer, and not nearly as wide angle as the one I posted. tried those, didn't like 'em.
The individual LEDs aren't nearly as wide angle style.
2005 GMC CC 4x4 D/A
Old 12-17-2009, 10:35 AM   #224
Gene's Avatar
Not exactly sure what you mean Rogerthat, but I did buy wide angle LED's from Superbright and they work fine.
Gene
ccd, led, lighting
LED Lamps for interior lights drboyd Electrical - Systems, Generators, Batteries & Solar 56 06-05-2011 11:06 AM
LED Camper Interior Lighting Number99 Commercial Listings 2 02-08-2007 04:07 PM
LED Lighting. Devoman Our Community 3 03-14-2006 07:27 AM
LED lighting 74Argosy24MH Electrical - Systems, Generators, Batteries & Solar 2 12-04-2002 07:00 AM
