Old 11-19-2014, 05:31 PM   #1
hutch309.2
hutch309.2's Avatar
1983 34' Limited
Amherstburg , Ontario
LED Lighting
I have a 1986 34 Limited Airstream and looking to up grade all the interior lighting with LED. My question is...there a led bulb that would fit into the existing socket? I don't relish the thought of rewiring all the interior lights.
I would also like to upgrade the backup lighting, stop and signal as well.
Would appreciate your input so as not to get into a major project.
hutch309.2 is offline   Reply With Quote
Old 11-19-2014, 05:34 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes.
I have done on my 1999 34' Excella
http://tinypic.com/m/idw4xx/3
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-19-2014, 05:35 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Contact Dan at LED4RV.com
He knows his products!
Old 11-19-2014, 07:24 PM   #4
2010 22' Sport
Lexington , South Carolina
Ditto on LED4RV.com
Dan just set me up with LED's all around for my 2010 sport. Good company to do business with.
Mrucr is offline   Reply With Quote
Old 11-20-2014, 07:13 AM   #5
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
A third for LED4RV.com
Dan will even return phone calls if you have any questions.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 11-20-2014, 07:13 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you can solider you can do the complete trailer for the cost of one bulb.
I did my 34 for $20.00.
Remove the fixture, drill out the bulb socket and add the LEDs as desired. The LEDs come in a 16 ft. long tape and can be cut every 4 ins. The strips are wired in parallel. On the larger fixtures I wire some on the low switch and all on the high switch. 1 fixtures including the florescent valance light in the bathroom.
The LEDs I used are a higher kelvin level that the normal warm light of a bulb resulting in a bluer light. The LEDs can be purchased in warm white if desired.
2004 Excursion 4x4
Old 11-20-2014, 09:43 AM   #7
hutch309.2
hutch309.2's Avatar
1983 34' Limited
Thanks Howie, I have no problem with soldering as I had my own appliance business and soldering in those days was routine. I was looking for replacement LED bulbs that would replace the old style bulbs. Going this way would be more expensive???.
Will there be a merchant at Int'l that will be selling LED lighting? Thanks for the help.
Old 11-20-2014, 03:45 PM   #8
HowieE's Avatar
Images: 12
You may find vendors selling LED bulbs at the different rallies but I doubt they will be selling the tapes of LEDs. I bought mine on E Bay.
2004 Excursion 4x4
Old 11-20-2014, 04:40 PM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Not entirely sure it's relevant here, but our 67 rig used 1142 bulbs in the high-intensity lights. I ordered LED replacements for those as well as for the 1141 bulbs for the overhead lights. The 1141 replacements all worked great; the 1142 replacements wouldn't work at all.
It was quite a mystery, but here's strange result. The replacement bulbs look kind of like this:
Looks like a straightforward replacement, right? The two contacts on the bottom would be positive low and high intensity, and the base of the bulb is negative. Not! On these dumb bulbs, the base is not connected at all electrically; the two contacts on the bottom are positive and negative, the whole bulb having only a high intensity feel to it. This is, in other words, not a replacement for the 1142 bulb.
Duh! Cruddy manufacturing. Rather than return them, though, I cheated. Lowered one of the two contacts on the bottom and ran a flat copper wire from it to the base. Raised the other bottom contact. In this way, I routed positive to the one contact and negative from the bulb base.
Ok, it only has high intensity, but that's really ok since that's all we ever really used anyway. And I didn't alter anything on the Airstream itself so that, at the next go-around on this ... assuming I last that long!!
Lynn
WBCCI 21043
Old 11-20-2014, 05:41 PM   #10
hutch309.2
hutch309.2's Avatar
1983 34' Limited
Hi Eubank:
I just went out to our trailer and took one of the light bulb out of the over head bank of 6 bulbs and the number on this bulb was 1157 which has two contact. The light over the sink bulb has " looks like " 1141 has only one contact. The LED picture you show has 2 contacts which would fit out trailer. It seems like an expensive project to replace, as there are 3 of these, one in living room, kitchen and bedroom.
Old 11-20-2014, 06:19 PM   #11
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Yep, the 1141s that I replaced with LEDs had only one contact at the bottom, and the LED replacements, also with a single contact on the bottom, all worked well. They are kind of like these:
It was the replacements for the 1142 bulbs (two contacts on bottom; base as negative) that were goofy.
Lynn
WBCCI 21043
Old 11-20-2014, 06:36 PM   #12
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Where did you get the 1141 and what was the cost of them
shepherd57 is online now   Reply With Quote
Old 11-21-2014, 01:55 AM   #13
2005 19' Safari
GLENDALE , AZ
Last year, we replaced all of the incandescent bulbs in our 2005 19' Bambi and had good luck with LED bulbs from this vendor:
1141/1156: http://www.eversale.com/catalog2_1/p...ail-5050-p-181
Same LED bulb as above, except with wedge base, instead of bayonet: http://www.eversale.com/catalog2_1/p...ulb-2825-p-232
1142/1158: http://www.eversale.com/catalog2_1/p...ail-5050-p-231
1157: http://www.eversale.com/catalog2_1/p...ail-5050-p-209
Notes:
1. Link to 1157 is provided for reference only. Our Bambi does NOT use this bulb in any lighting fixtures.
2. All of these bulbs are "warm white" and are the same brightness and color as incandescent bulbs.
3. I have no affiliation with EverSale.com, except as a satisfied customer.
Old 11-21-2014, 07:17 AM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
I used ebay, just searching for "led replacement" and bulb number.
Lynn
WBCCI 21043
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
