Old 09-10-2010, 05:34 PM   #1
1968 20' Globetrotter
Kelowna , British Columbia
LED light FIXTURES
Does anyone know a source for led fixtures suitable for ceiling mounting? Lots of threads show up in my search with information for replacing bulbs in existing fixtures, but I need new fixtures since my Airstream was gutted before I got it.
Canlib is offline   Reply With Quote
Old 09-10-2010, 07:53 PM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
led fixtures
If you are looking for an inexpensive plastic fixture the Kaper II led dome light is available for around $50. I saw these at an RV show but was unable to find out just how many lumens of light they produced. They seemed a little dim. If you want something a bit nicer try one of the Marine store like West Marine. They usually have stainless steel led fixtures which would look very nice in your Airstream.
I was also in an Ikea store recently and they had several types of under the counter led tube lights. The lights were powered by a small 12v transformer that plugged into standard household 110v outlet. I would assume you could power them directly from your 12v.
fltlevel510 is offline   Reply With Quote
Old 09-10-2010, 08:32 PM   #3
pbearsailor's Avatar
Port Hadlock , Washington
I'm using LED Puck lights from VTS
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-11-2010, 09:56 AM   #4
Thanks for the input! I'll have a look at Ikea...Marine Supply prices always scare me. Steve how do the VTS units mount? I can't see screw holes in the pictures. I was originally thinking I'd have to cut large holes in the inner skin, but those thin surface mounts could make my life easier!
Ian
Old 09-11-2010, 11:52 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I bought a complete fixture from Dan at led4rv, but haven't seen it yet as I have been away from home, forever it seems. Contact him, he's a great guy to work with. I will most likely buy more from him after my wife sees it lit and tells me if I like it of not.
LEDs 4, Recreational Vehicles
Old 09-11-2010, 03:23 PM   #6
Ian
Ian, the outside piece comes off and hides the three mounting screws. Only need a big enough hole to run the wires.
-steve
Old 09-11-2010, 04:15 PM   #7
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Another nice thing about 12V LED lighting is that you can use a basic potentiometer with a click-off position as a dimmer switch. This does not harm the LEDs and can extend their life and your battery life considerably.
TX-16
Dave Park is offline   Reply With Quote
Old 09-11-2010, 04:39 PM   #8
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Any difference between the "warm" LED pucks and the normal "bright"? And I'm going back and forth between the marine pucks at WestMarine and the pucks at VTS. Any recommendations are appreciated.
hampstead38 is offline   Reply With Quote
Old 09-11-2010, 04:58 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I don't think having a resistor inline to dim the LED will save your battery any at all. The potentiometer is just a variable resistor, and it is dissipating the energy that would have been consumed by the LED in a direct circuit, so it all looks the same to the battery.
Old 09-11-2010, 05:15 PM   #10
Dave Park's Avatar
2005 22' Safari
LEDs work based on current, not voltage, and resistors restrict current flow. The way LEDs dim, some will remain quite bright while others shut off altogether, so the current draw drops as the LEDs dim.
This reduction in current draw is the energy saving effect.
However, you could also use a 555 timer IC to create a PWM controller to achieve the same effect. I'd be happy to put up an open source circuit design anyone could use...
TX-16
Old 09-11-2010, 05:34 PM   #11
The warm light is a color temperature that's a little yellower, more like what a regular incandescent bulb does. There's sort of a bluish tinge with the normal LED. I like the warm one's much better.
-steve
Old 09-11-2010, 08:40 PM   #12
Thanks Steve, the VTS puck sounds perfect. Dave, I'd like to see the dimmer diagram. I'll experiment with the simple pot. solution too.
Ian
Old 09-11-2010, 09:03 PM   #13
1967 26' Overlander
Upperco , Maryland
I just ordered three and some other odds and ends from VTS. I'll take a photo of them after I get them installed.
Old 09-11-2010, 10:00 PM   #14
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I purchased a trouble light that is LED, its great I don't burn myself any more. The downside...it is only bright when you are staring at the LEDs. I am saddly disapointed at the light it doesn't produce. I am sticking with floresenct lights in my 67. Adios, John
Diesel1 is offline   Reply With Quote
Converting Slimline Flourescent Fixtures to LED wbcci3371 Electrical - Systems, Generators, Batteries & Solar 1 07-29-2010 11:08 AM
looking for light fixtures scotty2hotty Lights - Interior & Exterior 2 06-08-2010 08:56 PM
Need LED Light Fixtures ventport Lights - Interior & Exterior 0 04-06-2010 12:56 PM
1969 Light Fixtures? BakedTaters Lights - Interior & Exterior 3 10-08-2007 09:42 AM
ac light fixtures roadtrip07 Electrical - Systems, Generators, Batteries & Solar 1 10-24-2005 12:39 PM
