Old 09-13-2010, 10:22 AM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
For new fixtures for general illumination (rather than a spotlight) you may find that fluorescent lamps are a better alternative. The light is more natural, the fixtures are cheaper, and the amp draw for a given brightness is about the same.
Old 09-13-2010, 12:01 PM   #16
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
The current draw for LEDs is typically 30-40% lower than for CFLs, which are the most efficient of the florescent lights. Strip lights have an older style of ballast and are less efficient run off 12v as they require an additional driver circuit that is done electronically in the CFLs.
However, the LEDs have a 200-500% price premium to get that 30-40% saving, and do not include the fixture.
TX-16
Dave Park is offline   Reply With Quote
Old 09-13-2010, 09:15 PM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Depends. Many 12v fluorescent fixtures now have electronic ballasts. Mine do. And, some tubes are more efficient than others, due to the nature of the phosphor coating.
The relative efficiency of fluorescent and LED lighting is the subject of considerable debate especially when the goal is broad angle, diffuse illumination. With LEDs there are cost and brightness tradeoffs. Many LED fixtures are run at higher brightness than their peak efficiency point to reduce the number of LEDs required and therefore the initial cost. And, higher efficiency LEDs cost more and have lower CRI.
Old 09-13-2010, 09:18 PM   #18
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Don't know about all the fancy stuff, I just know the LEDs ain't very bright if you are wanting to see. Adios, John
Diesel1 is offline   Reply With Quote
Old 09-17-2010, 05:31 PM   #19
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
The box of LED lights has arrived. Light or not, they are going in.
hampstead38 is offline   Reply With Quote
Old 09-18-2010, 08:57 AM   #20
1968 20' Globetrotter
Kelowna , British Columbia
I'm eager to see pictures and hear your impressions about the amount of light!
Ian
Canlib is offline   Reply With Quote
Old 10-27-2010, 06:52 PM   #21
darryl97420's Avatar
1974 Argosy 28
Coos Bay , Oregon
BUMP
Any photos available of your lights installed?
darryl97420 is offline   Reply With Quote
Converting Slimline Flourescent Fixtures to LED wbcci3371 Electrical - Systems, Generators, Batteries & Solar 1 07-29-2010 11:08 AM
looking for light fixtures scotty2hotty Lights - Interior & Exterior 2 06-08-2010 08:56 PM
Need LED Light Fixtures ventport Lights - Interior & Exterior 0 04-06-2010 12:56 PM
1969 Light Fixtures? BakedTaters Lights - Interior & Exterior 3 10-08-2007 09:42 AM
ac light fixtures roadtrip07 Electrical - Systems, Generators, Batteries & Solar 1 10-24-2005 12:39 PM
