Old 02-03-2015, 07:52 PM   #1
slabatFB25's Avatar
2014 25' FB Flying Cloud
Raceland , Louisiana
LED light by steps
The small LED light by steps when out. While setting by a fire one night my wife noticed the small LED light fading in and out. I turn it off and on and it stopped working all together. I pulled the light off and found the wires going into the trailer. Has anybody every changed it out? If so can you tell me where the connection is to replace light? I’m thinking I may need to pull out a few inches of wire spice right there.
slabatFB25 is offline   Reply With Quote
Old 02-03-2015, 08:30 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
Check for power at the wires first...
Do you have pictures?
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-03-2015, 09:10 PM   #3
Poolman's Avatar
1983 31' Excella
Seabrook , Texas
Dont have LED's in my rig, but use them at work all the time. I have found many of them are fine, just need a little adjustment.
Some LED's have a two pronged connector that inserts into the housing where the power feeds the fixture. This connector can "slide" out of the housing just enough to do exactly what you described.
Anyway might be worth a shot before digging into the wiring.
Take the cover off the light to expose the led and see if yours is similar. If so give it a gentle shove toward the housing and see if that does it.
Poolman is offline   Reply With Quote
Old 02-03-2015, 11:25 PM   #4
mefly2's Avatar
2015 25' FB Eddie Bauer
Ours did the same ... ended up soldering a longer pig tail and using plug connectors on the re-install. The original wiring to the LED board was intermittent.
Old 02-04-2015, 08:20 PM   #5
2014 27' Flying Cloud
Stowe , Vermont
Is your AS still under warrantee? If it is, have your AS company fix it free. If not, call your parts manager for guidance.
VT Wanderer is offline   Reply With Quote
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 11:26 AM
LED motion solar lights for steps JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 10-08-2013 09:38 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
