Old 05-05-2011, 02:04 PM   #15
1973 25' Tradewind
waynesboro , Virginia
We have replaced all exterior lights and fixtures with led, only because the old fixtures had failed or rusted. I would like to replace my interior bulbs but I find the cost unreasonable, perhaps in a year or two the prices will fall...until
then I will live with what I have....
waltero is offline   Reply With Quote
Old 05-05-2011, 02:27 PM   #16
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We replaced all bulbs except the overhead halogens with LEDs. This gives us the option of conserving battery power while boondocking and having the halogens when we have shore power. It works for us.
Before the replacement bulbs were readily available, I installed a couple of surface mount LED pucks- one at the dinette and one in the galley. I still use them if get up early and don't want to wake Sam.
Old 05-05-2011, 05:48 PM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I originally installed one LED puck light in our bedroom so we don't get blinded by turning on the ceiling lights. Later I installed one in the kitchen and two in the living room area. I very seldom boon dock, but when I do, I won't have to use flashlights this time. To replace my interior lights with LED's at $20.00 each, it would run about $400.00 and that is money that I don't need to spend. [19 #1141 bulbs]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-05-2011, 09:12 PM   #18
Dan@LED4RV's Avatar
Denton , North Carolina
dimmers
Originally Posted by murreywalker View Post
Supposedly the 2012s have a dimmer built in.
Do you have any idea if a dimmer exists or will come into the marketplace anytime soon?
Some of the 2012's do have dimmers because the Bright white LEDs were so bright. However, the 2011 units that have the Bright White do not dim past 8 volts. Their voltage range is 8 to 30 VDC.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-05-2011, 10:05 PM   #19
1985 31' Excella
Fresno , Texas
I think these are cool light for indirect mood lighting. They only draw .1mA per fixture. This supplier also has a nice looking aluminum led reading spot light.
Could run some on cat5 stranded with different colors on different pairs.
SURFACE MOUNT <br>LED LIGHT FIXTURE from Aircraft Spruce
Wsmith is offline   Reply With Quote
Old 05-06-2011, 08:36 AM   #20
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I thought the cost of replacing all of the halogens with LED's was a bit expensive so I replaced all of the 10W halogens with 5W bulbs. The lighting is still sufficient and clean white light. I also found a pack of miniature LED cabinet lights at Home Depot at $30 for a pack of 12. They are 12V so you can wire them in directly. Added two to the bathroom and four in the closet because I have 4 shelves. May add a couple in the bedroom for boondocking night lights.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 05-06-2011, 09:31 PM   #21
Queen Creek , Arizona
I think I'm going to order a few of these and try them out.
Last year I had to have my generator rebuilt as well as replacing my batteries. That bill did not make me very happy. If I can replace all the lights with LED's and extend the life of these I think it will be worth the upfront cost.
Im going to order a few of these and soon and I will keep everybody posted on the results.
I just noticed they have two available. The one I posted above and a brighter version:
Rigid Industries RV LED Kit 400 Lumens | eBay
Which locations do you think these would work in best?
It seem as the folks that have tried these like them a lot.
Arstream is offline   Reply With Quote
Old 05-10-2011, 03:01 AM   #22
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Originally Posted by Jammer View Post
Dedicated fixtures designed from the ground up for LED applications will work better but are costly and are really only suitable for people redoing the whole interior:
Apeiron Warm White LED
Well that's good. If I'm selling all my vintage lights and starting anew, I guess it works out well that I was planning to install LEDs.
Just like when I installed solar on my boat though, decreasing the dependability on limited electricity supplies on long trips is invaluable. The difference of scales is being forced to walk around the trailer with flashlights and not have running sinkwater versus not having the power to run a bilge pump in an emergency scenario.
Regardless, I still feel like its worth it for a full renovation to install LED lights for everything. Especially if its only a 100 sq.ft. trailer...
Thanks for the useful thread guys, this is very helpful for a newbie comparing LED lighting options.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 05-10-2011, 04:58 AM   #23
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I originally had twenty 1141 bulbs in all interior lights. I spent around $100 to replaced one bulb with LED's in six of the two bulb overhead lights and one of the single bulb reading lights over the bed. I left one of the original 1141 bulbs in the second socket of the two bulb fixtures, except the one over the kitchen sink I installed both with LED's. This way I can use the LED's 95% of the time. When I need brighter task lighting I switch on the second bulb for a short time. This was my less expensive compromise/solution to excessive battery drain while bondocking. Most of the time I camp where there is shore power.
I am satisfied with the results!
I used seven of these: LED Bright White Light Cluster 20 LEDs B1156-20BWF [B1156-20BWF] - $11.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
I used one of these in the fixture where I installed the second LED in the kitchen: Large Warm White Pad 1156p48x68WW [1156p48x68WW] - $19.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
I use ODM for most of my parts since I'm only a twenty minute drive away.
Old 05-11-2011, 05:50 PM   #24
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Here's something for consideration about LEDs:
How many of us have lights in their fridges? I noticed in the relatively short time the door is open, two things happen. First, the bulb gets very warm (hot), and the fridge will have to work to coll the bulb back down after you shut the door. Second, for the time the door is open, there is a draw on the battery. If you open the door many times during the day, there will be a noticeable power consumption. The door may only be open a couple of minutes at a time, if that, but eventually that time will add up.
So, I pulled out the old bullet light bulb in ours, and installed an LED in its place. It's more than bright enough, and a bunch cooler. I singed my fingers removing the old bulb, and the door had only been open maybe a minute when I grabbed the bulb. It's part #F4LED-BW on www.led4rv.com's website. Here are before and after photos:
ID:	129637   Click image for larger version
Old 05-11-2011, 07:13 PM   #25
lewster's Avatar
Naples, FL , Hood River, OR
A little off topic, but relevant!
Remember that for every minute you leave the door open on a gas/absorption fridge, the unit requires 1 HOUR to recover the temperature loss!!!!
Put THAT in your pipe and smoke it!!!
Old 05-11-2011, 07:45 PM   #26
Well Preserved
1993 21' Sovereign
That's good to know for those with children that like to stand with the door open, cooling off the trailer...
Old 05-16-2011, 11:10 PM   #27
Well I placed my order from the Ebay link above a few days ago. I'm hoping they show up before this weekend so I can have some time to install and test them.
I noticed a few posts in other threads about over-volting the LED replacement's. I gave them a call and was told that the listed life expectancy and lumen output was based on a 14.44 volt input power. He insisted he has never heard of or seem a failure due to this and reminded me of the 2-year warranty. I was going to order a cheeper version but he also brought up the fact that they are made in the USA.
I will keep everbody posted on the results.
Thanks again for all the input!!
2011 27' FC led lights Road Geezer 2009-2015 Flying Cloud 7 01-10-2012 06:23 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
LED replacement for '64 Auto-Lamp 7" taillight Globie64 Lights - Interior & Exterior 8 03-12-2011 07:37 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
