Old 06-07-2011, 10:00 PM   #1
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
LED for Exterior Patio Light
I'm considering replacing the bulb in our exterior patio light on my 2004 Classic with an LED array that the Airstream store has. I see multiple arrays for sale. Here is one.
https://store.airstream.com/product_...roducts_id=423 (36 LED's)
Here is another.
https://store.airstream.com/product_...roducts_id=506 (24 LED's)
Has any one tried either of these? Obviously they would have to fit behind the lens which I need to replace since the original is partially melted due to the high heat from the 1156 bulb.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-07-2011, 11:30 PM   #2
spenfolder's Avatar
2006 16' International CCD
Salt Lake City , Utah
Here is another.
Jack
I used the pad from LEDs 4, Recreational Vehicles on my bambi and it works great. Plenty of light. I used the bright white because I like the look a little better on the outside.
Stan
spenfolder is offline   Reply With Quote
Old 06-08-2011, 05:36 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Replaced both the porch and step light with 4RV bright white LED's,
porch comes with new lens that needed a bit of trimming top edge, both give good amount of light.
I discovered a little moisture inside the porch fixture so I sealed the new lens in, LED should last a long time, plus I have OEM if needed.
Worthwhile upgrade, prompt service.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 06-08-2011, 09:57 PM   #4
jcanavera's Avatar
Fenton , Missouri
Images: 143
This is interesting since you both recommended the same product. What I didn't expect was the warning about the heat that these generate. I would have expected them to run cooler. The 36 led that Airstream is selling is supposed to run cooler than the 1156 bulb that originally is used.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2011, 10:02 PM   #5
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I used the recommended replacement from the Airstream store last year when at Alumapalooza I.
I can show it to you this weekend at Moraine View.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 06-08-2011, 10:12 PM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
Great!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2011, 10:13 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I did the patio light with a led array from airstream. great light. that clear focused lens and the led pad are a good combo. I used some of them inside and they are not as bright as I would like when on batteries. okay on power.
Old 06-09-2011, 08:02 AM   #8
richinny's Avatar
2011 34' Classic
jack, there are a few threads on this topic. this is one of them:
http://www.airforums.com/forums/f447...ing-67193.html
Ricky
Old 06-10-2011, 09:55 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Stan
Ditto ... And we got the one with the new lens attached because the original plastic lens had melted and was "sagging"...the LED produces very little heat. Problem solved.
TB & Greg and Abbey Schnauzer
#3954
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Report on LED int light replacments dljosephson Electrical - Systems, Generators, Batteries & Solar 28 04-18-2011 04:53 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 10:50 AM
