Old 02-07-2014, 11:24 AM   #1
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
LED for entry step light
I've changed to LED lights on about everything except the entry step light on the 25FB. Anyone know how to open it?
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-07-2014, 02:02 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Hmmm I have one identical on my PanAmerica. It is led.... are you sure it I'd not led already?
Ill see it I can break mine and let you know!
Old 02-07-2014, 02:08 PM   #3
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I have a 2009 FC 23, the parts manual indicates the step light is LED. AS part number 5122252.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-07-2014, 02:11 PM   #4
SteveH's Avatar
Common Sense , Texas
I need a new one on our '08 I think probably because the PO left it on too long, but I can't see how to open it or take it off either.
I sure would like to find out how to do it.
Regards,
Steve
Old 02-07-2014, 02:46 PM   #5
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
ditto on needing info on how to crack it open! I have successfully avoided breaking it open thus far but sure would like to take a look see in there to make sure it is sealed up properly. I have some dear friends who spent a pile of money to get a leak and floor rot remediated due to a step light leaking. These things sometimes reside in the runoff from the awning and get a frequent leak test from mother nature.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-07-2014, 02:48 PM   #6
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Maybe that's why it doesn't seen to be meant to be opened. It is sealed all around with caulk.
Antique Pedaler
Old 02-07-2014, 06:48 PM   #7
SteveH's Avatar
OK, but how does it mount? There are no screws are rivets visable. Do they install it in the skin and then build the trailer around it?
Regards,
Steve
Old 02-08-2014, 07:22 AM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I have the same one and several of the LED's are burned out. The only ones defective in all the ones I have had for many tears.
Ahab is offline   Reply With Quote
Old 02-08-2014, 07:39 AM   #9
SteveH's Avatar
So, no one here knows how to open it, or remove it?
Regards,
Steve
Old 02-08-2014, 09:00 AM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I believe it is a simple compression fit. Little plastic tabs apply pressure to the hole keeping it in place.
You could always give the mothership a ring and confirm on Monday...
Old 02-08-2014, 09:03 AM   #11
Alphonse's Avatar
Lower Alabama , USA
Okay; let's nominate someone to call Monday as Atomic as recommended.
Second thought, I volunteer to call on Monday and report back.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 02-08-2014, 10:28 AM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I love being called Atomic... makes me feel invincible!
Old 02-08-2014, 12:11 PM   #13
Dan@LED4RV's Avatar
Denton , North Carolina
Ur going to laugh
It is so easy it is hard. Here is a picture
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 02-08-2014, 12:42 PM   #14
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Okay Dan, thanks. The next question is....did it come with an LED bulb?
I don't really want to break the caulk seal around my light to open it. I'm on the road and the caulk is at home.
Antique Pedaler
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Buzzing sound; LED light related? brad1 Lights - Interior & Exterior 8 08-07-2012 07:22 PM
LED tape light boondockdad Lights - Interior & Exterior 2 02-11-2012 05:21 PM
LED for Exterior Patio Light jcanavera Lights - Interior & Exterior 8 06-10-2011 09:55 PM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 10:50 AM
