Old 05-30-2007, 03:56 PM   #1
2001 36' Land Yacht XC Diesel 300 hp w/slide
Terrell , Texas
L E D tail light Install??
Got new lights fron Airstream Dealer, got um installed, dont have turn lights eather side. New lights had wht,blk, red wires. Hooked up blk to blk, wht to wht, red to grn. Don't know it need to switch red and blk wires?? Looks like when lights on, might be stop/turn, instead of running lights. Any sugestions before I start taking them apart?? Would appreciate help. Thanks Jake Oesch WBCCI # 2340 Reply strawboss@o-tec.com
strawboss33 is offline   Reply With Quote
Old 05-30-2007, 05:42 PM   #2
Your selling dealer should give you all the correct wiring information. That's their job. They know what you purchased. We don't.
Old 05-30-2007, 07:28 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Jake,
You have the lights cross-wired. IIRC, a tail/brake combination LED fixture has 3 wires, red/black/white. The white is usually ground, the black tail and the red brake. Some manufacturers do not follow this and mix the black and red, or do their own thing entirely!!
You can test this with a 12VDC battery. Connect the white to ground and touch the black to positive. It should light. Notice the intensity of the LED. Then remove the black and replace it with the red. It should get brighter (brake). If it's the other way around, you still know which wire from the LED is what.
It should be a snap from there. Just match it with your trailer wiring and you're good to go!
The green on your A/S is probably ground, and you'll have to test for the tail and brake with a test light.
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 05:25 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
