On occasion, I have seen Airstreams with their running lights blinking while in a showroom... Upon closer examination, they have a blinker module plugged directly into the electric hookup that would normally go to the to the tow vehicle. Now... my simple brain tells me that if you were parked in a campground and wanted to put your running lights on just for "ambience", you should be able to cross-connect a couple pins in that connector. Has anybody done this? Any dangers that should be considered?
We made up gizmo to do this using connector from auto parts place with jumper wire (2") and two blade connectors. Trailer umbilical plugs into modified receptacle, and lights come on.. It can also be done with turn signal flasher, and jumper wires with blade connectors..
Condoluminum
Welcome to the forum! Use your search function above and you will find two great long threads on this subject.
Again welcome aboard!
Thanks!... I did use the search feature, but it generated way too many false hits. Gave up after an hour of searching and figured it may not have been discussed yet. Can you help point me to the right spot? From the other responses I have already received (quick!) it looks like it is doable... Just need the specific pins to connect across.. hopefully this is covered in the threads you mentioned. Thanks!
- Robert
Use an automotive blade fuse (10A is what I used to use I think) and plug it into the 7 wire cord, shorting the 12V and clearance lights together. They are right next to each other, and the blade fuse fits almost perfectly, even on the curve.
That's what I used to do, but now I have a switch in the inside of my unit to turn them off and on as I wish...
That's what we do, I also picked up a heavy duty blinker at a truck stop and it fits perfectly onto the plug so we can make our lights flash. Great for letting Sara know it's time to come in!
__________________ J. Rick Cipot Sandi Gould NEUNew England Unit Airstream Life Magazine WBCCI #3411 AIR #17099
Way cool. I have seen a battery pack thingie that cost about $50 that you plug your umbilical cord into to run your tail lights and running lights on if you have to abandon your trailer on the roadside at night and just assumed that's what people were using to do this. I'll have to get an extra 10 amp fuse and try this next time we are sitting around the camp site. Would never leave it while asleep, though. I don't trust something like that unattended.
Family of Disney Fanatics
WBCCI# 4821
We use the big E for camping and I like to leave the running lights on at night so I can find it in the dark. Also, I like to be able to leave the running lights on when the TV connected, but without leaving the TV's lights on. My solution was to buy another female connector and wire it to an old rotary automotive heater fan switch. I slipped the connector into one end of a piece of PCV pipe and put the switch into the other. I wired the switch to put power onto the tail light/running light circuit, the left, and the right brake/turn circuit. Now I can plug this gizmo into the trailer and test the lights without having the TV nearby.
It is convenient enough that I wonder why there isn't a commercial product like it.
We put our running lights on all the time at campgrounds. Clancyboy showed me how to do it.
Buy a small fused 14 gauge wire in the auto department at Wal-Mart for about 2 bucks. Put a 20 amp fuse in it. Crimp a couple of flat connectors to the wire ends. put the two connectors in the #1 and #7 contacts (those are the ones on either side of the key lug) in the Airstream's electric connector cord. All the running lights will come on and stay on until you pull the wire out. As long as you're hooked up to AC power, the converter will provide the juice. I usually leave them on all evening and have never had a problem. It wouldn't be a problem to add a 12 volt flasher unit into the circuit. I don't know how much your neighbors would appreciate flashing lights, though.
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
How about a "flasher" unit that will make the lights come on one at a time and cascade around the trailer. Flashing is easy, but what is really impressive is the cascading light display. Any ideas?
__________________ 74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
Reason: changed font to forums standard size 2
