Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-04-2007, 01:35 PM   #1
rvivrette
Profile:  2005 19' International CCD
Colorado Springs , Colorado
Question Keeping your running lights on?
On occasion, I have seen Airstreams with their running lights blinking while in a showroom... Upon closer examination, they have a blinker module plugged directly into the electric hookup that would normally go to the to the tow vehicle. Now... my simple brain tells me that if you were parked in a campground and wanted to put your running lights on just for "ambience", you should be able to cross-connect a couple pins in that connector. Has anybody done this? Any dangers that should be considered?
Thanks!
- Robert
rvivrette is offline   Reply With Quote
Old 09-04-2007, 01:37 PM   #2
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Robert-
Welcome to the forum! Use your search function above and you will find two great long threads on this subject.
Again welcome aboard!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 09-04-2007, 01:40 PM   #3
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Yes, paperclip comes to mind. A standard blinker switch will work to make it blink, the pins are about the correct distance apart.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 09-04-2007, 01:41 PM   #4
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Short version - yes...
We made up gizmo to do this using connector from auto parts place with jumper wire (2") and two blade connectors. Trailer umbilical plugs into modified receptacle, and lights come on.. It can also be done with turn signal flasher, and jumper wires with blade connectors..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 09-04-2007, 01:42 PM   #5
rickandsandi
1960 24' Tradewind
Exclamation
Use a fused line! A paperclip will either get very warm or blow a main-line fuse.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
Old 09-04-2007, 01:46 PM   #6
rvivrette
Cool
Originally Posted by rickandsandi
Robert-
Thanks!... I did use the search feature, but it generated way too many false hits. Gave up after an hour of searching and figured it may not have been discussed yet. Can you help point me to the right spot? From the other responses I have already received (quick!) it looks like it is doable... Just need the specific pins to connect across.. hopefully this is covered in the threads you mentioned. Thanks!
- Robert
Old 09-04-2007, 01:53 PM   #7
Bambi_Bandit
Bambi_Bandit's Avatar
Profile:  2008 27' International CCD FB
- Robert
Use an automotive blade fuse (10A is what I used to use I think) and plug it into the 7 wire cord, shorting the 12V and clearance lights together. They are right next to each other, and the blade fuse fits almost perfectly, even on the curve.
That's what I used to do, but now I have a switch in the inside of my unit to turn them off and on as I wish...
Bambi_Bandit is offline   Reply With Quote
Old 09-04-2007, 01:53 PM   #8
Jim Clark
Jim Clark's Avatar
Mine has done neither, but I like living on the edge.
Thanks Jim, N5TJZ
Picture Gallery
Old 09-04-2007, 02:46 PM   #9
rickandsandi
1960 24' Tradewind
That's what we do, I also picked up a heavy duty blinker at a truck stop and it fits perfectly onto the plug so we can make our lights flash. Great for letting Sara know it's time to come in!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
Old 09-04-2007, 03:00 PM   #10
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
Way cool. I have seen a battery pack thingie that cost about $50 that you plug your umbilical cord into to run your tail lights and running lights on if you have to abandon your trailer on the roadside at night and just assumed that's what people were using to do this. I'll have to get an extra 10 amp fuse and try this next time we are sitting around the camp site. Would never leave it while asleep, though. I don't trust something like that unattended.
Family of Disney Fanatics
WBCCI# 4821
Old 09-04-2007, 03:57 PM   #11
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Running light switch
Originally Posted by Excella CM
We use the big E for camping and I like to leave the running lights on at night so I can find it in the dark. Also, I like to be able to leave the running lights on when the TV connected, but without leaving the TV's lights on. My solution was to buy another female connector and wire it to an old rotary automotive heater fan switch. I slipped the connector into one end of a piece of PCV pipe and put the switch into the other. I wired the switch to put power onto the tail light/running light circuit, the left, and the right brake/turn circuit. Now I can plug this gizmo into the trailer and test the lights without having the TV nearby.
It is convenient enough that I wonder why there isn't a commercial product like it.
I posted a picture but it seems to be gone. You could easily add a blinker to flash the lights too. Look at these posts: Running marker / clearance lights unhooked
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-04-2007, 08:28 PM   #12
Excella CM
Excella CM's Avatar
Venice , California
Running light switch and tester
Here are some views of the unit I made to manually control the lights on the the Excella
ID:	44420  Click image for larger version
ID:	44422  Click image for larger version
Old 09-04-2007, 08:59 PM   #13
moosetags
moosetags's Avatar
Santa Rosa Beach , Florida
We put our running lights on all the time at campgrounds. Clancyboy showed me how to do it.
Buy a small fused 14 gauge wire in the auto department at Wal-Mart for about 2 bucks. Put a 20 amp fuse in it. Crimp a couple of flat connectors to the wire ends. put the two connectors in the #1 and #7 contacts (those are the ones on either side of the key lug) in the Airstream's electric connector cord. All the running lights will come on and stay on until you pull the wire out. As long as you're hooked up to AC power, the converter will provide the juice. I usually leave them on all evening and have never had a problem. It wouldn't be a problem to add a 12 volt flasher unit into the circuit. I don't know how much your neighbors would appreciate flashing lights, though.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 09-04-2007, 09:25 PM   #14
tinhutjohn
tinhutjohn
tinhutjohn's Avatar
Profile:  1974 29' Ambassador
London , Ontario
How about a "flasher" unit that will make the lights come on one at a time and cascade around the trailer. Flashing is easy, but what is really impressive is the cascading light display. Any ideas?
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
Last edited by Mel; 09-05-2007 at 08:16 AM. Reason: changed font to forums standard size 2
tinhutjohn is offline   Reply With Quote
No running lights! Bing-Bing Lights - Interior & Exterior 5 08-01-2008 07:34 AM
Running lights Devoman Our Community 16 03-21-2006 08:45 AM
led running lights anyone? wasafari Lights - Interior & Exterior 6 01-13-2006 03:51 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
Cooking Forum - Sailing Forum -
