Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-03-2008, 06:12 PM   #57
Fenghuang
Fenghuang's Avatar
Profile:  2007 23' Safari SE
San Diego , California
We are quite conservative with lighting when dry-camping rarely draining the battery lower than 75%. For example, we never use our halogen ceiling lights or reading lights. The plan is to eventually replace these with LEDs.
I tried the fuse and the flasher with the running lights only once and briefly while dry-camping to check it out since I wanted this for emergency road-side situations. We have 2 solar panels which charge up the batteries 100% by 9 AM during sunny days. We prefer to use candles or LED headlamps inside. LED Christmas lights draped around the trailer are quite impressive when hooked up to shore power.
Larry
Originally Posted by crazylev View Post
Oh man.
Fenghuang, thanks so much for the photos!!! That without doubt will be initiated on the "Lev Zeppelin".
I can't wait to try this.
One question for you all, and I think I know the answer to this, should you be hook up to shore power when you do this? I'm assuming you'd go through the batterys pretty quick if boondocking.
Thanks again.
Jonathan
"The only ones among you who will be really happy are those who will have sought and found how to serve"
Albert Schweitzer
Fenghuang is offline   Reply With Quote
Old 07-07-2008, 02:43 PM   #58
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I was just thinking about this the other day and couldn't remember the fuse size I had purchased or the slots to stick it into. Glad this thread popped up again...now I just need to go by the auto supply and get one of those flashers...uh...I mean alternating fuses.
Family of Disney Fanatics
WBCCI# 4821
Old 07-07-2008, 03:37 PM   #59
AirConditioner
AirConditioner's Avatar
Profile:
Audio Power Amp to Modulate Running Lights
If you're really into an audio/light show it's possible to size an audio amplifier to drive the lamps. Feeding about 10-15 watts of audio output into the light circuit with the other side of the audio amp grounded to the frame should provide adequate results. Just feed your favorite audio into the power amp. I'd have to calculate the wattage necessary - depending on the lamp wattage requirements @ 12vdc. When I get back in to Baltimore I'll run a few tests with an old tube amp for a baseline.
AirConditioner is offline   Reply With Quote
Old 07-07-2008, 11:34 PM   #60
grantb4
grantb4's Avatar
Profile:  2005 22' Safari
San Juan Capistrano , California
Do a Google search for Light Organ or Color Organ for more ideas.
grantb4 is offline   Reply With Quote
Old 07-09-2008, 10:35 AM   #61
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
I thought that that late 60's and early 70's were long gone
Light shows and color organs????????? The Doors Philmore East anyone?????
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-31-2008, 08:25 PM   #62
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Here is my go at it - I used 4" sch40 PVC pipe and flat end caps for the case - cost was the main factor. The two caps and 12 inches of pipe was under $4 at HD. Wire I had, switch is also from HD and is a 3 way (center is off, up is on constant, down is flash), power availlable light is from Radio Shack and was .89 cents. The 7-plug was the most expensive and from WalMart - around $8. All total I figure I have under $20 in the thing and it works great - I wired all the other circuits to the terminal strip for use later when I want to hook up more switches for testing. For now just the running lights. Oh yes, I put an inline fuse from the power lead and the flasher unit was on sale at WalMart for .49 cents in the red tag items.
ID:	64825  Click image for larger version
ID:	64827  Click image for larger version
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
No running lights! Bing-Bing Lights - Interior & Exterior 5 08-01-2008 08:34 AM
Running lights Devoman Our Community 16 03-21-2006 09:45 AM
led running lights anyone? wasafari Lights - Interior & Exterior 6 01-13-2006 04:51 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 09:54 AM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 09:55 PM
