We are quite conservative with lighting when dry-camping rarely draining the battery lower than 75%. For example, we never use our halogen ceiling lights or reading lights. The plan is to eventually replace these with LEDs.
I tried the fuse and the flasher with the running lights only once and briefly while dry-camping to check it out since I wanted this for emergency road-side situations. We have 2 solar panels which charge up the batteries 100% by 9 AM during sunny days. We prefer to use candles or LED headlamps inside. LED Christmas lights draped around the trailer are quite impressive when hooked up to shore power.
Larry
Originally Posted by crazylev
Oh man.
Fenghuang, thanks so much for the photos!!! That without doubt will be initiated on the "Lev Zeppelin".
I can't wait to try this.
One question for you all, and I think I know the answer to this, should you be hook up to shore power when you do this? I'm assuming you'd go through the batterys pretty quick if boondocking.
Thanks again.
Jonathan
