Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-02-2008, 12:33 PM   #43
welld.geo
Profile:  1977 31' Sovereign
ORD , Nebraska
Here's what I'm using
Here's what we're using to light our trailer. The housing can on the left can be bought at most department stores / home centers / auto supply houses for under 8 bucks. The innards on the right are correctly positioned to simply slide into the housing. This runs off of the main battery in the AS. The circuits are fused inside the tailer, plus I've got a 30 A (little high I know) on the hot wire. Hope this helps. Erik
welld.geo is offline   Reply With Quote
Old 07-02-2008, 01:50 PM   #44
2dabeach
2dabeach's Avatar
Profile:  2007 25' Safari FB SE
North/East , New Jersey
Originally Posted by ROBERTSUNRUS View Post
Hi, I went a little bit overboard, but it was fun building my own light box. It has a red pilot light to indicate that I have a power source and ground. A three way switch to control whether the lights are off, on steady, or flash mode. One switch to turn on the running lights and one switch to turn on the brake lights. The white lights were added to indicate which system was turned on and give the needed resistance to make the LEDs flash. Click on pictures for a better view.
Like your design. On two occasions I've had flats on my tow vehicle and had to disconnect the Airstream so the tire could be removed from the truck. Your device would have allowed me to keep the emergency lights flashing on the Airstream when it was disconnected from the truck. What type of flasher did you install in the device?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
WBCCI # 8459
2dabeach is offline   Reply With Quote
Old 07-02-2008, 04:32 PM   #45
SilverCabin
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Thumbs up
ROBERTSUNRUS,
Nice piece of work. Please post the plans and parts list.
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 07-02-2008, 05:26 PM   #46
DEITZ645
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 84
Originally Posted by SilverCabin View Post
ROBERTSUNRUS,
Randy
DITTO...Man is that neat. I wanna make one too.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 07-02-2008, 05:37 PM   #47
Fenghuang
Fenghuang's Avatar
San Diego , California
Sunset beach photo
Originally Posted by grantb4 View Post
Nice pics. Is that San Clemente?
It was taken this Spring at South Carlsbad State Beach.
I am quite impressed with the other devices. Thanks for sharing.
Larry
"The only ones among you who will be really happy are those who will have sought and found how to serve"
Albert Schweitzer
Last edited by Fenghuang; 07-02-2008 at 05:39 PM. Reason: need to add additional comment
Fenghuang is offline   Reply With Quote
Old 07-02-2008, 10:26 PM   #48
Aage
Profile:  Currently Looking...
Aurora , Ontario
Hi, start by rewiring the whole trailer with separate wires for each light. Next part, I don't have an answer for.
Here's an interesting way to do it. This clip is all AS, all the way.
Old 07-02-2008, 10:58 PM   #49
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Sorry!
ROBERTSUNRUS,
Randy
Hi, sorry I was unable to find my original wiring diagram and I never kept a parts list. In designing my light box I made a few changes in both parts and wiring so I would have to make a new wiring diagram to be accurrate. About half way through makeing it I saw an add for the "Light Cube" that TBRich posted a link to; [page 3 post #37] And the "Light Cube" costs less than I spent on parts. But as I have posted before, I'm very hard headed and had to do it my-way anyhow.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 07-03-2008, 01:10 AM   #50
trucker101
trucker101's Avatar
Profile:  1972 31' Sovereign
Regina , Sask.
Rivet Can Opener ??
Originally Posted by clancy_boy View Post
Now you guys have gone and done it - I'm thinking about a winter project - gotta have flashing lights at the Can Opener.........
Can Opener???
If you got it
A Truck Brought it!
trucker101 is offline   Reply With Quote
Old 07-03-2008, 04:04 AM   #51
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Originally Posted by trucker101 View Post
Can Opener???
The Can Opener is an AirForums rally in Destin, FL started 2 years ago by one of our members - Devoman. The rally is at the first of the year in a great spot. Check out the rally page for details.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 07-03-2008, 10:16 AM   #52
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Oh man.
Fenghuang, thanks so much for the photos!!! That without doubt will be initiated on the "Lev Zeppelin".
I can't wait to try this.
One question for you all, and I think I know the answer to this, should you be hook up to shore power when you do this? I'm assuming you'd go through the batterys pretty quick if boondocking.
Thanks again.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 07-03-2008, 12:24 PM   #53
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Originally Posted by crazylev View Post
Oh man.
Thanks again.
Jonathan
Yes, I would be on shore power if I was to do this for fun. In an emergency - such as on the shoulder of the road - and had to leave my trailer (hopefully never) then you could run this for several hours on a good battery.
Looks cool in a campground - the flashing tends to anoy neighbors, but the constant lights are nice around your campsite for visits and such.
One use I used was at a rally when a non-Airstreaming friend was coming over for the rally pot-luck, I had mine flashing to identify my camper from the rest of the "silver looking trailers" he had to wade through. You could use it to identify your camper in a campground for emergency services to find you real quick too.
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 07-03-2008, 02:13 PM   #54
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 35
Oh man.
Jonathan, I'd do this pretty commonly when boondocking, but it usually only for about on hour at dusk. I've never had a big problem with battery usage, but consumption is consumption when boondocking.
This mod is KILLER with the new LED markers that Airstream is now using. The only regular light that is light now is the license plate light and even that will eventually get switched to a LED.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 07-03-2008, 02:23 PM   #55
Westfalia
Westfalia's Avatar
Images: 35
That guy has WAY too much time on his hands. I love it!
Old 07-03-2008, 03:03 PM   #56
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thanks Clancy_boy and Westfalia,
I think using discretion is the key here. I know I be ticked if my neigbor had a mini Vegas set-up. And definitely NO flashing!!!
Jonathan
You
