On occasion, I have seen Airstreams with their running lights blinking while in a showroom... Upon closer examination, they have a blinker module plugged directly into the electric hookup that would normally go to the to the tow vehicle. Now... my simple brain tells me that if you were parked in a campground and wanted to put your running lights on just for "ambience", you should be able to cross-connect a couple pins in that connector. Has anybody done this? Any dangers that should be considered?
Thanks!
- Robert
Here's what I do. Works fine. No, I didn't fuse it, maybe I should but I've never had a problem (till now of course). Suggest for the flasher you get a heavy duty one.
it's funny, this very thing came up on another thread yesterday so I posted my pics there as well. Great minds think alike.
Barry
__________________ The best things in life are health, family, friends and enjoying your Airstream in a campground. Wally on Bro
Barry & Donna Life is short - so's the door on an Flying Cloud (ouch)
For you guys that want to have flashing lights, without getting "those strange looks" when you ask for a flasher for your travel trailer, you want a #552 flasher,, or electronic equivalent.
Thank You, I'm going by Flying J to look this weekend.
The next logical step if you wuld be a better flasher
Why not take a 12Volt photo relay and combine it with one of those cheap l.e.d. flashlights that can automatically flash Morse code SOS signals? Then you can have your rig lights flash S.O.S. if you get into a real bind.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Use of 10 volt blade fuse to operate running lights
Thanks Kevin for the idea of using a fuse. Here are photos of my trailer's LED running lights operating without being hooked up to the tow vehicle, and a photo of the fuse in the plug.
"The only ones among you who will be really happy are those who will have sought and found how to serve"
Albert Schweitzer
For those who are squeamish about sticking wires into your umbilical cord, there is a product called a FlashCube that you can buy...you plug the umbilical into it and you can have the running lights on and/or the rear flashers working while not hooked to the TV. It's not particularly cheap, but at least you know for sure that you are not going to blow anything. Here's the link: flashCube - Emergency Flasher and Campsite Illumination
TB & Greg...Cockers Annie & Sadie...and Homer the Desert Tortoise
Hi, I went a little bit overboard, but it was fun building my own light box. It has a red pilot light to indicate that I have a power source and ground. A three way switch to control whether the lights are off, on steady, or flash mode. One switch to turn on the running lights and one switch to turn on the brake lights. The white lights were added to indicate which system was turned on and give the needed resistance to make the LEDs flash. Click on pictures for a better view.
Purdy dang slick! (Not to mention cool.)
