Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-04-2007, 11:04 PM   #15
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Originally Posted by tinhutjohn
How about a "flasher" unit that will make the lights come on one at a time and cascade around the trailer. Flashing is easy, but what is really impressive is the cascading light display. Any ideas?
Hi, start by rewiring the whole trailer with separate wires for each light. Next part, I don't have an answer for.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 09-04-2007, 11:40 PM   #16
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
First...Robert...welcome to the forum and thanks for asking this rousing question! Got lots of responses... Glad you asked, as I was wondering how to make the running lights shine while we were camped...I think that would be really cool. Now if I don't electricute myself or fry something in the Bambi... Glad you ahve joined up with us! It's a great group...
Originally Posted by moosetags
We put our running lights on all the time at campgrounds. Clancyboy showed me how to do it.
Buy a small fused 14 gauge wire in the auto department at Wal-Mart for about 2 bucks. Put a 20 amp fuse in it. Crimp a couple of flat connectors to the wire ends. put the two connectors in the #1 and #7 contacts (those are the ones on either side of the key lug) in the Airstream's electric connector cord. All the running lights will come on and stay on until you pull the wire out. As long as you're hooked up to AC power, the converter will provide the juice. I usually leave them on all evening and have never had a problem.
Second...Thanks, Moosetags for detailing how to do this... Does there happen to be a "store-bought" gizmo to do this? I'm a bit of an electrical chicken...ever since I stuck scissors into an electric outlet as a kid. Talk about running lights glowing!
TB
Old 09-04-2007, 11:40 PM   #17
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Nice idea, but since these lights are wired in series, you would have to access the wire to each light and connect them to an electronic sequencer. If you're re-wiring a vintage unit, keep this in mind as a fun project!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 09-05-2007, 06:15 AM   #18
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
They are really wired in parallel, two 6v batteries wired to make 12v would be series.
What would be really cool, at least for a while, is to wire the lights to the sequencer so they would flash in time to the radio. I thought I was really cool when I wired my car radio and running lights this way, until it did its own little version of three mile island. Ccircuit protection is a must.
BTW, for some reason, wiring the lights to operate in the campsite is called "Canadian Christmas Lights" around here, not sure exactly why...
Old 09-05-2007, 07:13 AM   #19
henw
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
Who's got a pic. Is it 1+6. 1+7. Or, 3+4.
Tom
henw is offline   Reply With Quote
Old 09-05-2007, 08:31 AM   #20
Jim Clark
Jim Clark's Avatar
New Orleans , Louisiana
You could put an addressable module switch in the base of each light then address each light. You could control the lights with a laptop, embedded chip, or a million other ways. This would save the rewiring and only cost you a few hundred to a few grand.But you would not have to rewire.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 09-05-2007, 08:57 AM   #21
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Tom
Look at your 7 pin connector on your trailer. Hold it so that the outside rim "key" (the little bump that keeps it aligned in the socket) is up - it's the two sockets on either side of the key. The left one will be power the right one is the lights. Use a FUSED connector, they are cheap - I don't even crimp a connector to the bare wires - seems to hold well - just shove it in there. There may be a spark - you will jump every time - I do.
I want to make a gizmo like above with a flasher unit inside - can you post some parts lists and wire runs for us all??
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 09-05-2007, 09:24 AM   #22
SilverCabin
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
What size fuse?
10a or 20a fuse? An earlier post (#7) said 10a.
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 09-05-2007, 09:58 AM   #23
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
I use a 10 - I think it's a red one.
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 09-05-2007, 10:05 AM   #24
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
10a or 20a - in either case they will blow fast if there is a dead short. I use the yellow 20 amp fuse - I had to buy a box one time and that was the package size that Wally World had. I checked mine and on my trailer the light circuit is protected by a 20 amp fuse, so one or the other will pop if you accidentally touch the power to ground.
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 09-05-2007, 11:37 AM   #25
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Seems like the right answer and might not be that expensive. Using l.e.d. lights would reduce the current switching and you could have just about any pattern you wanted. Also, a simple timer circuit at each light, each one with a progressively longer base would give sequential lights, although the intervals might "drift" over time, but that might not be bad either. Definitely an amateur electronics project.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-05-2007, 12:06 PM   #26
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Now you guys have gone and done it - I'm thinking about a winter project - gotta have flashing lights at the Can Opener.........
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Old 09-05-2007, 01:21 PM   #27
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I'm so dense, I'll do good to cram a 20 amp fuse in the umbilical without blowing up the Airstream in the driveway much less get it to work at the Can Opener!
Family of Disney Fanatics
WBCCI# 4821
Old 09-05-2007, 01:27 PM   #28
Minnie's Mate
Flashing is easy...
Yes, but I believe it is illegal in all 50 states.
WBCCI# 4821
No running lights!
