Old 03-31-2011, 09:07 PM   #1
RichHog's Avatar
1972 23' Safari
Houston , Texas
Keeping running lights on while camping
So at a recent rally everybody had a plug connector that keeps the running lights on when connected to shore power. Not sure which 2 pins connect together on the 7 pin umbilical connector. Bought a trailer connector Male plug and can't tell looking at it is which one when removed from the housing. So am wondering which 2 pins connect together to keep the running lights on? Don't see any numbering on this connector so a photo or graphic would help, or clear description. Thanks
RichHog is offline   Reply With Quote
Old 03-31-2011, 09:20 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if someone posts a picture or link of a seven pin connector you will able to see which pins to use. People have used wire, flashers, and what-have-you to do this. I built two control units for this purpose. The first one is more like an expensive toy and the second one is more for use during a roadside emergency.
ID:	125850   Click image for larger version
ID:	125852   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-31-2011, 09:51 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
The 7-way connector is also Known as a "Bargman Connector" Used Mainly on House Trailers and Now as OEM Plugs on Current Model Pick-up Trucks.
CAR END/TRAILER END
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 03-31-2011, 09:58 PM   #4
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I want one!!!
4RXLA is offline   Reply With Quote
Old 03-31-2011, 10:42 PM   #5
JFScheck's Avatar
Rockville , Maryland
Images: 33
Here - you can purchase this for 20.00 bucks from RVGlow and you will be set to glow...
Man, I crack myself up...
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 03-31-2011, 10:45 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If you refer to Airslide's post, connecting terminals #4 and #5 will turn on your running lights.
I slightly bent the connectors on a flasher to slide right into the plug on the trailer. It will cause the running lights to flash. I keep the flasher handy so that if I ever have to unhook and leave the trailer along the side of the road at night, it can be seen. Never have had to do that, but nice to know that I can.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 03-31-2011, 10:58 PM   #7
Salem , Oregon
Images: 18
Hi, on my simple unit, it only has one switch and it is only an On-Off switch. I connected an in-line fuse holder with a 20 Amp [Yellow] fuse to the Black/battery pin. The other end of the in-line fuse holder was connected to one of the wires on the toggle switch. The other wire on the toggle switch was connected to one side of my flasher unit. Then I connected the Brown Green and Red wires together at the other pin on my flasher unit. So when the switch is in the on position, all of the running lights and all of the brake lights flash.
ID:	125856   Click image for larger version
2005 Safari 25-B
Old 03-31-2011, 10:59 PM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The easiest way is to take a spare 10 or 20 amp automotive fuse and stick it in the two connectors on either side of the key notch on the trailer's umbilical. This will burn your running lights and give you a protected circuit for virtually no cost.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 04-01-2011, 08:00 AM   #9
JFScheck's Avatar
Images: 33
That's a great (easy and inexpensive) solution - but I'm such a paranoid wimp (and too lazy to build one) that the $20.00 "RVGlow" product will put me in the comfort zone for those times that I want the running lights illuminated on the Airstream and it might be raining outside...
In Between Units
Airstream On Order
**I Love U.S.A.**
Old 04-01-2011, 09:02 AM   #10
RichHog's Avatar
1972 23' Safari
Houston , Texas
Thanks guys for the postings. Didn't find a thread on this so started a new one.
Love the idea of the toggle switch!
Old 04-01-2011, 09:08 AM   #11
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Having one is cool if used at dusk through early evening. Keeping it on all night is really annoying to your neighbor when the lights light up the bedroom. We like to sleep with windows & curtains open (weather permitting). Please be considerate when using one of these.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 04-01-2011, 10:43 AM   #12
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I use a wire bent in a horseshoe shape and stick the ends into the umbilical at the 11 and 1 0'clock positions. But looking at Airslide's diagram, I don't see how it is possible that mine work. But they do....
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-01-2011, 10:49 AM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
I put a switch inside to perform the same function. It is particularly useful to turn on the running lights in bad weather (so people can find the trailer) when digging around the tool compartment and hooking things up to the umbilical is no fun.
Old 04-01-2011, 10:50 AM   #14
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
I use a 30A fuse holder stuck into the slots on either side of the notch for steady on or a heavy duty flasher with the blades slightly tweaked for flashing.
I don't think Airslide's pic is correct either???
B25guy is offline   Reply With Quote
running lamps at camp
Side running lights GeocamperAS Lights - Interior & Exterior 4 03-13-2011 09:15 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Lens removal for orange running lights on 1973 model AirHome Lights - Interior & Exterior 6 02-07-2011 09:42 PM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
