Old 10-31-2010, 06:22 PM   #1
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
Is there 110 near the control panel in front cap
Is there any 110 in the front cap. Want to put a set of lights on bottom side of cap under the control panel. There are a lot wires that ran behind stero but don't think any are 110
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 10-31-2010, 06:29 PM   #2
No, there is not any 120 VAC in the front cap.
But, you can easily feed a wire from one of the 120 VAC outlets, that are on each side of the front lounge.
Old 10-31-2010, 06:59 PM   #3
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Thanks Andy, i was a bit concerned that there may be a rib to contend with. I'll give it a try.
Thanks a million.
Richard
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
Old 10-31-2010, 07:56 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
When I was running wires in my TradeWind I found the fishtape kept getting stuck in the insulation. I already had the trim off the wing windows so I drilled out the pop rivets holding the skin to the window frame. After that it was easy to reach up and route the tape into the end cap.
With all the 12vdc wiring up there what prompted you to choose 110 lights?
Good luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 10-31-2010, 07:59 PM   #5
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Not going to boon dock
Wife found a set of really great lites at HD , better for reading.
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
Front end cap 73 Safari SafariGeorge Upholstery, Blinds, Walls & Interior Finishes 2 08-19-2010 07:24 AM
Help- Control Panel went out all at once milesmason Electrical - Systems, Generators, Batteries & Solar 10 06-29-2006 08:56 PM
Control Panel RUSSELL Electrical - Systems, Generators, Batteries & Solar 4 08-04-2004 09:38 PM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 04:48 PM
310 front cap Bfrank General Motorhome Topics 11 07-25-2002 08:36 PM
