Old 09-14-2011, 02:23 PM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Is it okay to have 12 volt light grounded to skin or frame..
I installed a couple of walmart 12 volt license plate lights to replace the step light and the sewer connection light. The lights are designed for a car and have one lead and ground through the base. I soldered a wire on the base and hooked it up as a two wire light. But that still leaves the body of the fixture, and thus the neutral lead, connected to the skin. Is that okay or not??
Old 09-14-2011, 02:27 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The 12V ground should already be bonded to the frame somewhere, so you're just providing an additional path for grounding to the shell with the body of these lights. As long as you don't reverse the connection on the wires coming into the fixture you should be fine.
— David
12 volt
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
'88 Excella tail light bexel (or mounting frame) okiedebi Lights - Interior & Exterior 0 06-18-2011 02:10 PM
sticky black tape between interior skin & frame? clipperguy Ribs, Skins & Rivets 1 03-21-2011 04:00 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
