Old 07-06-2011, 10:23 AM   #15
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Originally Posted by Scott J-24 View Post
Dan,
I will take a pic and post when we get back from our trip. We are staying at the new State Park CG in Laguna Beach (Crystal Cove SP El Moro). Great location with 4 million dollar ocean views from each campsite.
Dan,
Here are the pictures you wanted to see. My concern was that I didn't know if they popped off or if they twisted off. Tried both, but didn't want to break the fixtures. Since we only use these lights when cooking, I figured keeping the halogen bulbs there wouldn't be too big a power draw. The first picture is the underside of the range hood and the second one is a close-up of one of the light fixtures.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-06-2011, 11:01 AM   #16
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
Just what I've been looking for. Thanks to all for the many sources for LEDs.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is online now   Reply With Quote
Old 07-07-2011, 05:15 AM   #17
Air Mobile
2005 25' International CCD
Newport News , Virginia
As was just said...you guys are great and thanks for all the great leads on replacing out the halogen bulbs.
Does anyone have any downside stories to relate on switching to LED, is there any reason to stay with the halogen I may have overlooked...other than costs...
Tim_S is offline   Reply With Quote
Old 07-07-2011, 05:48 AM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by overlander63 View Post
Here also are some direct plug in replacements for the halogen capsules:
9 LED Warm White Chip C9WW [15751W-09] - $11.95 : LEDs 4, Recreational Vehicles
Dan,
You can use the same LEDs I linked in my post above. I've installed them in the range hoods, and they work and look very good.
Old 07-07-2011, 01:57 PM   #19
Scott J-24's Avatar
I know the LEDs will fit, my problem is getting the covers off the fixtures in the range hood. I tried to pop them off and tried to twist them off but the cover on the fixtures didn't budge and I didn't want to break the fixture (did that at home with a puck light ). Does anyone know if these pop off or are they twist off covers?
WBCCI #1215
Air #54601
Old 07-07-2011, 04:23 PM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
They look like the ceiling lights in ours. If so, there is an inner and outer ring. Carefully insert a thin knife blade between them and gently pry the inner ring out until you can get it out with something like a screwdriver. The aluminum scratches really easily, so carefulness is a good thing.
Gene
Old 07-07-2011, 04:36 PM   #21
Well Preserved
1993 21' Sovereign
Gene
Oops. If I'd read more carefully, I'd have known that . A thin blade knife or flathead screwdriver will work to get the lenses off, as Gene has indicated. A picture would be great, if you ever get them replaced. I'm always busy doing too much to stop and take photos.
Old 07-07-2011, 04:48 PM   #22
Master of Universe
Gene's Avatar
I used a thin blade because the space between the 3 rings requires it. Most screwdrivers have tips that are too fat. I know this because I tried it with a screwdriver and it slipped and scratched the fixture.
Gene
Old 07-07-2011, 05:15 PM   #23
Scott J-24's Avatar
Gene
Gene,
No these are not like the other ones in the AS. I have already replaced all of those halogens with LEDs. They were just like you described with the inner rings that you can open by inserting a thin knife blade or fingernails. These have a solid plastic ring around the lens (no inner rings like the others).
WBCCI #1215
Air #54601
Old 07-07-2011, 05:16 PM   #24
Scott J-24's Avatar
Terry,
See the photos in post #15.
WBCCI #1215
Air #54601
Old 07-07-2011, 07:14 PM   #25
Well Preserved
1993 21' Sovereign
Terry,
AFTER you get the LEDs installed...
Old 07-08-2011, 12:36 AM   #26
Dan@LED4RV's Avatar
Denton , North Carolina
looks differant
Here are some pictures of a new hood range and these look differant from yours. I can tell CrawfordGene has this same kind in the pictures but yours (Scott) look differant. Have you tried to take the filter out and see if it gives any clues? Maybe look with a mirror?
The knife is at the first ring like Gene talked about. It came right out.
The below picture shows a little clip and the hole it goes in. It has 3 of them and they all 3 have to line up.
Another interresting this is the lens is glass and if it were to break I bet it would be hard to find. Hard to find with out buying the whole light.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 07-08-2011, 08:33 AM   #27
Scott J-24's Avatar
Dan,
Yes, the light fixtures in my range hood are different from the photos you posted (no inner ring in my hood lights). The puc lights in my kitchen are similar to those in the AS but some twist off and some pop off. I like the idea of taking a look at the back of the fixture via the range hood filter. But if this doesn't provide a clue I will probably leave it as a halogen light until it burns out since we don't use it that much anyway.
WBCCI #1215
Air #54601
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
LED Tow Vehicle to LED Trailer Problems murreywalker Hitches, Couplers & Balls 25 09-10-2012 03:42 PM
Airstream int'l ccd 28 ft. eBay Watch Airstreams on eBay 0 05-05-2011 09:40 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
