Old 11-08-2014, 06:50 PM   #1
Salt Lake City , Utah
Is coverting to 12V this simple?
I've got a 23 foot Kenskill 1964. Pretty much intact. Im going to boondock in it with solar.
Can I just change out all the 120 incandescent bulbs for LED 12v screw ins, Then cut off the plug, connect the circuit to my batteries and go on my merry way? Of course I couldn't use shore power henceforth.
Every one seems to run a separate circuit for 12v in some form.
Any guidance appreciated!
Glen W. is offline   Reply With Quote
Old 11-08-2014, 07:12 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello. I think there is an internal circuit difference between 12v LEDs and 115v LEDs. I don't think you can screw on in a 115v socket and power it with 12v. You might be able to change the bulb socket to a 12v bayonet socket and then redeploy the wire as a 12v wire. Actually you may not need a socket at all as LEDs will last longer than the camper. Just hard wire the LED array. I'd ask the RV LED or one of the other internet suppliers.
If your trailer is like an Airstream, you may have a converter in it somewhere. Airstream went to all 12v devices sometime in the mid sixties. They called it univolt.
So I think you're going to need to do some electrical planning to convert your old camper to all 12v, solar charged, and maybe a converter to charge batteries on 115v too. Maybe you need a 12v water pump, a 12v ceiling vent fan, and a 12v furnace fan?
David
12v
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
The Simple Life...simply stupid! yukionna Off Topic Forum 56 08-05-2004 12:19 PM
"Simple Life" - Initial episode jordandvm Our Community 6 06-09-2004 01:31 AM
Super Simple Polish Method Safari Tim Cleaning, Stripping & Polishing 8 08-08-2003 08:17 AM
