Old 03-14-2012, 11:56 AM   #1
2009 25' FB International
Naples , Florida
Intermittent Under-Cabinet Light - '09 25FB Intl
There are 3 LED's under the cabinet over the rear dinette that are working intermittently. The three are on one switch and the switch is one of a bank of four just inside the outside rear door. All other lights controlled by the other three switches are fine. I'm betting it's something simple but I'm not much of an electrical troubleshooter. Any suggestions? Thanks you all.
bbherb is offline   Reply With Quote
Old 03-15-2012, 01:11 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
pull the lights
I would pull down the light closest to the switch and see if the wires are not loose.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 03-15-2012, 07:47 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check the common/ground connection on the light fixture. There is probably a wire (white) going to the skin of the trailer.
Solo Considering a 23D or a 25FB Twin need counsel rodsterinfl Solo Streamers 38 09-10-2013 04:38 PM
value of roof spot light gloran General Motorhome Topics 8 04-21-2012 09:01 PM
Under Consideration: 1970 Sovereign Int'l CarrieSue Trailer Values 19 04-01-2012 10:01 PM
Questions about towing a 25FB with a F-150 barrettjl Towing, Tow Vehicles & Hitches 32 03-13-2012 11:13 PM
mantle for gas light Globie64 LP Gas, Piping, Tanks & Regulators 8 03-09-2012 09:36 PM
