Old 10-19-2016, 08:15 PM   #1
Georgia Rolling Stone's!
2018 25' International
Peachtree City , Georgia
Interior Overhead Lights went dim
Hi everyone…I am a Newbie here. I have a 2012 25' Flying Cloud.
Last weekend I was plugged into shore power at a campground.
Used a 50 amp to 30 amp plug in. I had the Use/Store switch in the "Use"
position. Two days later I went to turn on my overhead lights and they would
only go to dim. I looked at the Indicator panel above the sink and the
battery indicator light was red and blinking. If I was on shore power
why would my battery light be red and blinking and my lights go dim?
Thank you for your help. I appreciate you!
hstone is offline   Reply With Quote
Old 10-19-2016, 08:17 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
For whatever reason, your converter was not charging your batteries.
CRH is offline   Reply With Quote
Old 10-19-2016, 08:22 PM   #3
Thank you!
Old 10-19-2016, 09:19 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Battery voltage charging and at rest?
MICHAEL
Old 10-20-2016, 03:05 PM   #5
2015 27' FB International
Rancho Palos Verdes , California
Did you flip the shore power breaker on?
RPVEd is offline   Reply With Quote
Old 10-21-2016, 09:28 AM   #6
1975 31' Sovereign
West Liberty , Kentucky
I had the same problem this summer. Found the plug on the converter had vibrated loose from the receptacle. Plugged it back in and everything was ok.
Air4563 is offline   Reply With Quote
Ceiling lights flicker, tail lights are dim Zeitlupe 2011 - 2015 International 11 07-01-2016 08:29 AM
Lights dim when hooked up to shore power Goodokie Electrical - Systems, Generators, Batteries & Solar 3 09-22-2012 07:59 AM
Clearance lights get dim? Chopper Electrical - Systems, Generators, Batteries & Solar 6 09-25-2006 11:37 AM
dim lights dallas Electrical - Systems, Generators, Batteries & Solar 7 08-23-2006 09:25 PM
Why are my brake lights so dim? balrgn Electrical - Systems, Generators, Batteries & Solar 4 09-11-2005 02:38 PM
