Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 02-22-2019, 07:46 AM   #1
1971 31' Excella 500
Santa Rosa Beach , Florida
Interior lights not working in 1971 Excella 500
We are new to Airstream and are beginnig to think that we are too dense to own one. That being said, our interior overhead lights are not working. Plugs do but nothing else. We have no idea where the fuse box is located even after looking at our owner's manual....
Any help will be most appreciated!
mey4693 is offline   Reply With Quote
Old 02-22-2019, 08:10 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hi and welcome to the vintage Airstream hobby. There is a lot to learn about your trailer and these Forums will be very useful to you.
Okay, when something electrical doesn't work in your trailer, you gotta be a good doctor and run some test to diagnose the illness.
1. Do none of the 12 volt lights work? Or do some work?
2. Do the roof vent fans work?
3. Does the water pump work?
4. Go buy a "digital multimeter" at your hardware store. Set it on DC voltage. Set it on 20 volts. Touch the black probe to the negative post of your battery. Touch the red probe to the positive post of your battery. We want to see at least 10 volts there. If less, you might have a dead battery.
5. You mentioned your "plugs" work. Some call them outlets. So you plug your trailer into 120 volts and your outlets work. Maybe your air conditioner does too (caution, don't run the AC unless you are plugged into 30 amp service. You can run the AC fan on low only, but no Low cool or High cool settings.)
6. So with your trailer plugged into 120v service, go test the battery again as in #4 above. Your converter ought to be delivering maybe 14 volts DC to the battery. If not, then your converter may not be plugged in, may have blown a fuse, or may be defective.
7. Many converters are "plugged in" to an outlet. Find your converter and confirm it is plugged in. Take a little lamp, or hair dryer, or your new multimeter and verify there is 120 volts being delivered to the outlet your converter is plugged into. If yes, then we will study the converter. If no, then we will verify there are no tripped breakers in the power distribution panel maybe located in a closet somewhere. You have to have 120v AC power to the converter. '
8. You have to figure out if the converter is delivering good voltage to the battery to keep it charged up, and if so, the converter is delivering good voltage to the rest of the trailer.
9. The converter will have a couple of fuses somewhere on it. If no lights yet, pull the fuses and make sure they are not blown, open, and kaput.
With some testing, you will likely find out the reason you have no 12v lights in the trailer. Note: All vintage Airstream hobbyists have a multimeter to diagnose problems. It is an important tool for your tool box.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 02-22-2019, 09:05 PM   #3
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Welcome to the AirForums!
This is a link where you can download an Owners Manual for your trailer.
https://www.airstream.com/wp-content...manual-132.pdf
Start reading at page 43.
The manual gives you some specific locations for all main electrical components
Originally the trailer had a power cord that rolled in and out. There are no parts available for those types of cord/recoil systems. Many have been rewired for a different type of power cord. If yours is not on the roller, then you know it has been rewired/modified. If so, anything is possible! Just inside the access door there was a junction box. That is where I connected the power cord when I rewired mine.
Alan
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Trailer lights brakes marker lights not working bwaysteve General Repair Forum 1 04-30-2018 07:31 PM
Brake lights, turn signals, reverse lights not working! HELP! blogworthy Argosy Motorhomes 6 04-16-2018 06:21 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
