Old 05-26-2008, 06:03 PM   #1
1974 27' Overlander
Placerville , California
Interior lights don't work on battery
Say have not had a chance to look into it to deeply and have not owned this Airstream very long. 1977 Overlander has no lights working when running on battery. The power is there because the water pump works and the light works on the overhead console. Probably not the right name, I am talking about the device that measures your tank levels and so forth. Any easy thing I might look into to get the lights to work with battery. Works fine when pluged in. Thanks for all the info the forum is great.
ronsgto is offline   Reply With Quote
Old 05-26-2008, 06:44 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I would guess a fuse, or a bad connection in the fuse panel.
Old 05-27-2008, 09:57 AM   #3
1974 27' Overlander
I will check that out did know if there was some kind of weird thing since lights work with power but not battery.
Old 05-27-2008, 10:12 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Not sure about a '74, but on our '64 you have to flip a switch between "battery" and "city power" in the electrical box ~
Shari
Aux lights do not work myfirstrv Land Yacht/Legacy Motorhomes 3 11-05-2007 12:03 PM
Brake Lights Don't Work spat61 Land Yacht/Legacy Motorhomes 3 09-28-2007 07:33 PM
Finally ready to go and the lights don't work RBolton Lights - Interior & Exterior 9 08-09-2006 06:01 PM
Some 12v lights don't work bjstewart1 Electrical - Systems, Generators, Batteries & Solar 6 07-22-2003 05:42 AM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
