Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-10-2018, 10:44 AM   #1
1977 Argosy Minuet 6.0 Metre
Vail , Colorado
Interior lights and water pump not working 77 argosy minuet
I had this camper plugged in with an extension cord for a long time and I seem to have overloaded some plug ins or something bc my breaker tripped and cut off everything. I flipped it back and all my plugs work now, but still no lights, water pump, or radio. I found a chewed wire that I spliced back together and wrapped with electrical tape. I've also found a wire that is just loose and not hooked up like the rest. It's the only wire with an inline fuse in it. Not sure where it goes. Any help would be much appreciated and I'll respond with more pictures and info as we start to solve this thing. I've included a video, and sometimes that loose wire will touch the shell of the camper and I can feel some current when I touch the door so that wire is hot.
Thanks in advance
johnboyjohn is offline   Reply With Quote
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
