Old 01-05-2008, 10:59 AM   #1
Bonaire , Georgia
Interior Lights
I have an 06 Safari and having problems with the interior lighting. The switches in the light fixture are going bad. The ones that have stopped working are all controlled by the rocker switch on the wall. I can press the switch on the light and it is as if the clicking mechanism has broken. I am thinking it will be asier to replace the light than to try to replace the switch inside the light fixture itself, or would removing the switch and straight wiring the light to work only with the rocker switch be the best move? Has anyone else had a similar problem?
benehana is offline   Reply With Quote
Old 01-05-2008, 11:03 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hello benehana -- Welcome to the Forums! A guess is that you are talking about the plastic case lights -- under the rear cupboard over the dinette and another above the sink. Is that right? I haven't experienced this yet. I did have one of the corner swivel spots that had a short and was completely replaced under warranty.
5 meter Langford Nahanni
Old 01-05-2008, 11:12 AM   #3
Bonaire , Georgia
Thats correct. The lights that have sopped are one in the bathroom and the one on the bedroom. The light under the cupboards and in the shower are still working fine.
Old 01-05-2008, 03:18 PM   #4
Colonial Airstream NJ
Colonial Airstream's Avatar
1961 16' Bambi
1997 19' "B" Van Airstream 190
Millstone Township , New Jersey
Images: 79
Hello,
We have experienced similar problems with the older style lighting Airstream used on the Safari line trailers pre 2008. If the light has been left on for a long period of time, the heat makes the switching mechanism very brittle and causes the lens to warp.
Patrick Botticelli - Colonial Airstream 595 State Hwy 33 Millstone Township, NJ 08535 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 01-06-2008, 05:23 AM   #5
Bonaire , Georgia
Thanks Patrick. Is there a suitable replacement for these lights?
Old 01-06-2008, 04:49 PM   #6
1961 16' Bambi
Images: 79
Yes, there is a suitable replacement for the older light fixtures. Airstream now uses a fixture that has heavy-duty housing and hard- plastic lens. I am not sure what brand they are, but they are available from Airstream or through an Airstream dealerships parts department.
No interior lights java71 Batteries, Univolts, Converters & Inverters 7 07-16-2011 11:03 AM
interior lights towguy Electrical - Systems, Generators, Batteries & Solar 4 06-27-2005 01:03 PM
Interior lights trio Lights - Interior & Exterior 5 08-25-2003 09:03 AM
interior lights jaiman Electrical - Systems, Generators, Batteries & Solar 1 03-03-2003 11:43 AM
Interior lights Daddy4Bob Airstream Motorhome Forums 9 09-25-2002 03:29 PM
