Old 03-02-2014, 10:57 AM   #1
1992 25' Excella
Puyallup , Washington
Interior light switch problem
Front ceiling light in our 92 Excella 25 classic had a intermittent faltering switch, now is completely out. Confirmed power coming into fixture. Can I get access to the internal switch to play with it? Appears to be a sealed light unit and don't want to mangle it or fully replace it if there is another option.
Newnest5424 is offline   Reply With Quote
Old 03-02-2014, 11:22 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Are you referring to one of the 14x14 large fixtures? Is it florescent or bulb?
The switch for the ceiling light is usually by the door. What switch are your referring to?
Picture may help
2004 Excursion 4x4
Old 03-02-2014, 11:26 AM   #3
1992 25' Excella
Sorry - not clear enough on info. Original ceiling light with 2 bulbs, slide switch with 3 positions on plastic fixture - off, one bulb, and both bulbs.
Old 03-02-2014, 11:49 AM   #4
HowieE's Avatar
Images: 12
Are you sure the bulbs are good? Test them out of the fixture. Often inheritance is a broken filament that makes and brakes itself.
Never had one of the fixtures apart but I would check for voltage directly in the bulb socket. If you have power there see how the fixture is grounded
2004 Excursion 4x4
What's the worst problem you ran into? Eaglemate On The Road... 16 10-29-2011 05:32 AM
Change over relay switch rickyduncan Electrical - Systems, Generators, Batteries & Solar 0 09-11-2011 05:00 PM
Brake controller adjustment problem Zettervall Brakes & Brake Controllers 9 08-30-2011 07:58 PM
Bad Switch On Bathroom Fan jambie Lights - Interior & Exterior 10 03-23-2011 09:41 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
