Old 10-20-2018, 08:50 PM   #1
silverslppr's Avatar
2006 16' International CCD
2008 25' Safari FB SE
Chicago , Illinois
interior light issue
We have a 2008 25 FB which we switched over to LED lights about 3 years ago. The trailer is always plugged into a 30 amp connection. We have a TRC Digital Monitor that went off during our previous camping trip mid Sept. (The campsite breaker went bad and we lost all power from the post before the campground sent out an electrician to replace the circuit breaker on the post.) Last weekend we camped again and when we went to flip on the light over the dinette, nothing. Then we tried the corner reading light in the dinette, and the same. When we returned home we first replaced the LED bulbs with new ones that worked in other fixtures in the trailer. Again nothing. We check the voltage with a tick tracer and we do have voltage going to each socket. Because our TRC went off before the power at the post went out, might we have a damaged inverter? Would it affect only two interior lights? The inverter is 4 years old. Could it be something else? Thanks we are really stumped.
Rosie
"SilverSlipper"
Michael & Dyanna
silverslppr is offline   Reply With Quote
Old 10-20-2018, 10:45 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would suspect a blown 12 volt fuse. They should be on the 12 volt distribution panel.
Also, a converter supplies 12 volts to the lights and battery, not an inverter.
Richard
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 11:19 PM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 06:45 PM
1964 Overlander Interior light Issue 64Overlander Lights - Interior & Exterior 13 07-09-2009 12:08 PM
Interior Light Issue '64 Overlander 64Overlander 1960 - 1964 Overlander 5 06-17-2009 12:43 AM
