07-16-2007, 11:25 AM
2007 19' Safari
The Woodlands
Interior light bulbs burning out quickly
I have replaced at least 6 bulbs in the interior lights since we bought our AS new about a year ago. I did not keep a log of which ones, so I am not sure if I have replaced the same one more than once. Usage times have been minimal as we have only had it out 5 times. When we returned from out trip last week, I checked the voltage. On battery it runs just a shade over 12V, but when connected to electricity, it goes to 13.4 V. Could this be causing the bulbs to burn out pre-maturely ?
Any other ideas ?
Also, the covers seem to be constantly coming out/off. They are a pretty flimsy and cheap light fixture. Has anyone found a good replacement or fix to the existing set-up ?
07-16-2007, 11:31 AM
Remember, Safety Third
Catfish Corners
, Georgia
WHat type of bulb? Halogen?
07-16-2007, 11:46 AM
1984 31' Excella
Abernathy
hate to bring this up, but.....
running gear balance?.....are you shaking the trailer to death when you tow it?
07-16-2007, 11:57 AM
2007 19' Safari
The Woodlands
There was one halogen bulb burnt when I got it home (poor pre-delivery check by dealer, but that is a different story and Thread). I replaced it. then numerous of the 12V bulbs in the overhead lights have burnt also.
I'm not sure the rough roads would be causing this as the lights are never on while in tow.
07-16-2007, 12:04 PM
1984 31' Excella
Abernathy
This has nothing to do with rough roads or light on while towing.
It has to do with the hub assembly not being properly balanced as a unit resulting in lots of vibration throughout the trailer as it is towed, even on smooth roads.
Such vibration could cause the filaments in the bulbs to break, or cause the covers to consistently be coming out/off. The covers coming off is really the clue to me that your running gear might be out of balance severely unless the quality of the fixture is really that inferior.
The only other things that could be the cause in my opinion are poor electrical connnections resulting in overheating the bulbs, or just a bad batch of bulbs.
07-16-2007, 12:13 PM
2007 19' Safari
The Woodlands
Interesting thought, but these are 12 volt bulbs just like those in our TVs. I have had some bulbs (running lights, etc) in my vehicles last 100K miles and they are off and/or on while traveling down the road.
The covers are coming off while it is sitting still. Have not had one come off while traveling down the road (yet anyway).
You could be on to something with the heating issue though. If the bulbs are heating up, the lenses could be warping from the heat.
I too have thought about a bad (or cheap) batch of bulbs. I am now keeping a log of which bulbs I have replaced to see if I am just weeding out the initial batch that came with it.
07-16-2007, 12:31 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
All filement type bulbs crystalize the fliments as they age due to temperature and time. Higher voltage from the converter will cause the bulbs to run hotter and crystalize more. As they cyrstalize they become more brittle and succeptable to breakage due to shock and vibration. The fact that the fixtures are in the ceiling and the insulation immediately behind them may make the fixtures run hotter than the home kind of mounting they were originally designed for. Too bad the halegon bulbs are not as cheap as regular incendesents. You could always convert to LED lighting, No heat very resistant to vibration and much more energy effiecient.
t
07-16-2007, 12:44 PM
2007 19' Safari
The Woodlands
t
The higher voltage was something I considered could be causing or contributing to them burning out, if 13+ volts is too high. I wouldn't expect AS to warranty bulbs, but if the power converter is the issue, then its a horse of a different color.
07-16-2007, 02:25 PM
Aluminut
2004 25' Safari
I've had a few burn out too, but nowhere near what you are describing.
If in fact it is the running gear killing the lights, you have far bigger problems than just the lights. To shake to death a bulb like this doesn't take a little bit of shaking.......
07-16-2007, 02:57 PM
1978 31' Excella 500
Venice
Over voltage is the most likely culprit. Youy may need to rig up something to monitor the 12 volt circuits actual voltage.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
07-16-2007, 03:40 PM
Jupiter
13.4 volts is within allowances as a "12V system" is a generic term with automobiles an example of running at battery charging voltage not simple battery output as a twelve volt battery reading twelve volts is close to being fully discharged.
Your 2007 model diffusers coming off sounds like a fit and finish problem coupled with Texas sunshine and high temperatures causing the latch mechanism to release spontaneously.
Halogen bulbs are notoriously hot - hot enough that any oil from being handled will carbonize on the bulbs glass envelope which then absorbs light and raises temperatures high enough to promote early failure. Cleanser over-spray by an exuberant delivery prep person or somesuch may even play a role on a rash of original lights going out...
A plain paper towel to handle the bulbs - and rubbing alcohol to rinse the glass off pre-emptively. Even handling with tissues can be wrong since many brands have lanolin or other moisturizers incorporated into the paper.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
07-16-2007, 03:43 PM
2007 23' International CCD
Lapeer
, Michigan
I have had a few hallogens burn out and was told upon replacement while I was at JC for other service to not touch the bulb with my bare fingers that it would burn out more quickly and to use a tissue or something to handle the bulbs, so far the new bulbs haven't burned out yet.
07-16-2007, 04:22 PM
Retired.
, At Large
The bulbs should be standard #1141 automotive type bulbs, such as that commonly found in backup lights. If you are continually replacing one bulb (though from your post it doesn't look that way), try checking the voltage, and the ground. Bad ground will cause increased heat in the bulb and fixture. Usually with a bad ground, you will notice the bulb being dimmer than the other bulbs, or flickering.
You can try a LED replacement for one of the problem bulbs, and see if it does anything squirrelly.
07-16-2007, 05:22 PM
1978 24' Argosy 24
Woodinville
As stated the 13.2 is normal "12 volt" operation. A 12 volt battery is actually six cells in series that are all 2.2 volts each. If you check the battery on your car it will be 13.2 volts too if it's fully charged.
You're only loosing interior bulbs, rigth? If it were vibration from the running gear you'd be popping tail lights, running lights and brake/turn indicators. I would have to suspect a large AC ripple from your charging system. If you have a good digital multimeter set it to AC and see what sort of value you get. On straight battery power it should be near zero. If you then see an AC component kick in when you plug in to shore power then I would suspect the charger/inverter.
-Bernie
07-16-2007, 05:57 PM
1990 34' Excella
Parsonsfield,
, Maine
In automotive use, bulbs are subjected to varying voltages due to the state of charge in the battery. The voltage regulation circuit allows higher voltages from the alternator to the battery, (and everything connected to the battery) until the battery reaches full charge. Voltages of 14 voilts or higher are common and yet we don't see this problem in automotive usage. A loose or corroded connection on an individual light will cause a voltage drop across the resistance of the bad connection. That should not cause higher voltage across the lamp in fact just the opposite. An interrupted circuit caused by a loose connection can cause a voltage surge when the circuit makes again and if that connection were say at a battery post, a surge can occur but that would blow every single bulb that was on at the time. Maybe you have one fused circuit with multiple bulbs connected in parallel that is interrupting, causing all bulbs on that circuit to blow. My 1990 AS has all circuit breakers for the 12v circuits. Maybe you have a bad circuit breaker or more likely a loose screw holding a wire at a circuit breaker. I would check all the screws on the circuit breakers, it's possible the factory forgot to tighten one srew. If you do, disconnect one battery cable at your battery(s).
It doesn't sound to me like an excess voltage problem, but more like a surge problem. I remember as a kid I was driving my dad's car, at night, that had a 6 volt battery. A loose battery cable caused every light bulb that was operating to burn out. Headlights, tail lights, every dash panel light etc. Fortunately I was able to switch to high beams and drive home before the connection interrupted again. Charlie E
07-16-2007, 10:06 PM
Salem
, Oregon
Hi, burned out bulbs or broken filiments? Broken filiments can be seen by looking at them and sometimes by tapping on the glass. Burned out bulbs, sometimes but not always, turn colors. [Black, silver, or cream] If the bulbs have turned colors when burned out, it could be high voltage, unstable voltage, or vacuum leak in the bulb. Broken filiments can happen due to vibrations or just weak / cheap bulbs. So the first thing I would do is determine if the bulbs are burned out or have broken filiments.
As for all the lights burning out on a car; It is caused by the chargeing system putting out too high a voltage. A bad voltage regulator or a bad battery connection can do this; the chargeing system needs the battery for reference to determine how much voltage to put out. Without the battery, the regulator will spike the voltage to whatever the generator is capeable of putting out.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-16-2007, 10:43 PM
Catfish Corners
, Georgia
Just to add something else to the mix. We replaced our over-the-sink light in the kitchen (not the Airstream) with a new halogen fixture about 18 months ago. We went thru about 5 bulbs in that darn thing the first year. About 6 months ago, I tested the fixture with a multi-meter and found about 6 volts on it with the switch turned off. Replaced the wall switch and everything is normal since.
07-17-2007, 04:27 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
The overhead bulbs in the new trailers are halegon 12 volt dc bulbs. They were originally designed for the low voltage light applications used in homes. The overhead bulbs in older trailers use backup automotive bulbs that are also 12 volt DC bulbs but were designed to be used in autos. The halegon bulbs operate very differently than the old auto bulbs. The temperature is much hotter. This can cause them to overheat the fixtures and warp the plastic part of the glass lens holders, if the fixtures are not properly mounted the way they are in houses. Airstreams do not have the room to properly mount the fixtures and Airstream engineers may not have properly accounted for proper cooling and have forgot they need to remove all thermal insulating material from around the fixtures to allow them to cool properly. Household halegon bulbs were not designed to endure road abuse. They are also designed to be powered by simple transformers from houshold 120 volt power which is more closely regulated than power you may be receiving from your converter on your trailer.
If you read the packaging for the replacement halegon bulbs, they caution against handling the bulbs with bare hands. Improper handling can shorten the bulb life dramatically.
07-17-2007, 06:53 AM
2007 19' Safari
The Woodlands
The bulbs in my overhead (ceiling) lights have a round base with pins on both sides and a glass glove containing a filament. When installing you line up the pins on the bulb with the slots in the socket, press against the spring tension then twist into its seating area. They look just like the standard tail light bulbs in my 64 Corvette. Are these halogen bulbs ?
I had to change one halogen bulb in the light (looks like a trac light) over our bed, and just as you mention, the instructions stated not to handle with bare hands. This bulb was much smaller and had a flat area with wire terminals that pressed into the socket. This bulb has been fine since installation.
07-17-2007, 06:54 AM
2007 19' Safari
The Woodlands
Thanks !! I'll check mine to see if something similar is happening.
