Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-14-2019, 03:58 AM   #1
Kensington , Maryland
Interior LED cabin lights not working
2017 FB FC
The LED cabin lights, all nine of them, stopped working. Currently, not a pun, plugged into shore power.
Everything else on the trailer works and the 15 amp fuses are good. I've pulled and reseated the fuses.
Bad dimmer switch?
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 06-14-2019, 08:22 AM   #2
Solved...for now.
The dimmer is separately fused (see picture). Replaced the fuse and all is well.
Now why did it pop?
Old 06-15-2019, 04:10 AM   #3
That worked for 24 hrs. Fuse popped again. Now I need to find the issue.
Do I methodically drop all the lights and look a ground fault?
What's the best approach?
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
LED Replacement for Halogen Cabin Lights nangoff 2002 - 2005 International 19 10-27-2014 10:56 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
