Old 05-16-2011, 04:44 AM   #1
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Interior ceiling light swap out help
For some reason I hate those lights around the vents on my 72 Overlander. Has anyone swapped them out for a different type of lighting? I would love some ideas and pictures.
DougZ
TAC FL-1
W4JDZ
DougZ is offline   Reply With Quote
Old 05-16-2011, 04:51 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I upgraded mine from the incandescent to fluorescent tubes to gain more light and loose the power drain and heat. Kept the covers.
Aaron
WBCCI #XXXX AIR #2495
Old 05-17-2011, 03:43 PM   #3
Jklep65's Avatar
1976 27' Overlander
Rosendale , New York
How?
Jklep65 is offline   Reply With Quote
Old 05-17-2011, 03:48 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Originally Posted by Jklep65 View Post
How?
Took the old sockets off the backing plate and installed 8 watt thin line naked lights. They only have a ballast and the minimal fittings. I wired them into the old rotary switch so you get one or both lights. I will have to try and take pictures when I do the next set.
Aaron
Old 05-17-2011, 03:50 PM   #5
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Lots of ideas with LEDs...many here have swapped over
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 05-17-2011, 04:56 PM   #6
DougZ
Airstream has some replacement flourescent fixture that are the same size.
The only problem is that they want over $200.00 for each one.
Old 05-17-2011, 06:29 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Which is why I built my own.
I bought my 8 watt lights several years ago for ~$20 each, they currently run around $30 each. Sixty bucks and a couple of hours to rework each fixture works for me. I not only cut the heat coming off the fixtures I got more light and gained battery life.
Aaron
Old 05-17-2011, 06:44 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Just for a break down:
My OEM fixtures used six 1141 automotive style bulbs, they are nominally rated for 12v 1.44 amps 17.3 watts. Six of them suck down nearly 9 amps when on high. The two thinline fixtures are 8 watts a piece and only use 1.25 amps for the pair. And provide approximately 80 equivalent watts of light. FWIW the fluorescent gives 400 lumens of light per 8 watt fixture, for a total of 800 lumens the 1141 gives ~260 lumens per bulb total would be around 1560, so the fluorescent technically aren't as bright, but I think they give much more usable light.
I do still use incandescent bulbs in the front reading spot lights, but will consider putting LED replacements in those...eventually, if someone makes them.
I have not tried LED bulbs in this application so no comment on those.
Aaron
Old 05-18-2011, 12:29 AM   #9
Jklep65's Avatar
1976 27' Overlander
Ok speaking of lights the light over the counter/sink, the one around the ceiling in kitchen area the light over the door and the reading light over the goucho are all not working. Do I have a blown fuse, tripped breaker or a mouse chewed wire? Any thoughts??? Oh 77 overlander.
Old 05-18-2011, 07:33 AM   #10
Check the fuses.
Old 05-18-2011, 07:47 AM   #11
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Remove the fuses and check them with a continuity checker. Don't assume they are good because the element looks intact. I wasted a lot of time making that stupid assumption.
TAC FL-1
W4JDZ
Old 05-18-2011, 07:49 AM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Smaller Bulbs
I relamped most of the original fixtures in our trailer. The original 1141 bulbs were too bright and too hot for my liking and consumed way too much power. The 1141 produce 200 lumens each (as I recall). The new bulbs produce between 69 and 90 lumens, depending on the part number. I bought the bulbs at NAPA. I can provide the part # if anyone is interested.
Old 05-18-2011, 08:00 AM   #13
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Aaron
If your trailer uses the same 1383 bulb in those reading spots that my Argosy does, there are LED equivalents.
Here's a link to the ones that show up in Google Shopping. They ain't cheap! I haven't gotten that far yet, so I have no idea what the quality of the light is.
David
Old 05-18-2011, 08:49 AM   #14
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I believe that is the number. Thanks for the link. I will stick with my $2 incandescent for now.
Aaron
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
2011 F250 Clearance/side LIGHT swap... THEPILL Tow Vehicles 33 03-06-2011 02:14 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
