Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 08-01-2013, 09:50 AM   #1
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Installing exterior lights-to seal or not to seal
I am Installing the exterior lights on my '73 GT. When I pulled them off (pot-metal mounts for some of the clearance lights and the tail light housings), I found that no sealant was used in their original mounting, and that lots of water, dirt, debris, corrosion and ant colonies of developed behind them over the years.
I was considering gooping them up with vulkem before reinstalling--does anyone see any downside in doing this?
thanks!
Old 08-01-2013, 10:01 AM   #2
2019 27' Globetrotter
Missouri Valley , Iowa
When I resealed OEM lights after purchase of my trailers, I left a small gap on the bottom lowest spot of the housing to let any potential accumulating water escape. I used Vulkem and masking tape to make a neater appearance. It seems that I have read here on the forums that others have left a gap also.
Dan
Farmer Dan is offline   Reply With Quote
Old 08-01-2013, 10:06 AM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I mounted mine on gaskets. No leaking in 3 years.
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 10-25-2013, 10:09 AM   #4
Mixter's Avatar
1976 27' Overlander
Belegedhel- I'm about to re-attach my tail light assembly's.
Have you have tackled this yet? How did you re-attach the assembly? I assume yours is like mine, and was riveted from the inside, but the rivet holes on the assembly did not go completely through the tail light assembly (bezel?). What I mean is that the rivets are simply embedded in the aluminium casting.... I imagine the original rivets were 1/8 pop. Did you go up a size to 5/32? Did you just drill out the rivets further down into the casting and then pop new 5/32 into it from the inside?
I too, have the same idea of gooping up the back side of the assembly with vulkem, when I attach. They probably do more around the seams...
Thanks!
Mic
Mixter is offline   Reply With Quote
Old 10-25-2013, 10:22 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I went the extra mile and drilled and tapped my tail light bezels and then installed Helicoils, so I was able to use threaded fasteners to hold them on. Check out my thread below to see how I did it
Aerowood is offline   Reply With Quote
Old 10-25-2013, 01:20 PM   #6
JimGolden's Avatar
1977 31' Excella 500
Berkeley Springs , West Virginia
I did the same thing Farmer Dan did. I sealed all around the top, the sides, and half the bottom. I left about 2" unsealed at the bottom. My thinking was that no matter what I do, some moisture will probably get in there, so I left a place for it to run out.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 10-25-2013, 09:54 PM   #7
Mixter's Avatar
1976 27' Overlander
Aerowood- that's sweet! I'll have to think about that.... might be more than I want to attempt though....
Everyone else just riveting into the cast aluminum? I've never riveted into something without going all the way through it.... Works just fine?
Old 10-26-2013, 07:14 AM   #8
Belegedhel's Avatar
Houston , Texas
I ended up gooping liberally with vulkem, and then re-pop-riveting them with 1/8th rivets. I did add another couple of holes just for good measure. The rivets seemed to bite just fine in the casting with the hole not going all the way through. Word of caution if adding holes--it's easy to drill too deep or miss the casting.
