Old 05-20-2016, 09:48 PM   #1
1991 25' Excella
Stanfield , Oregon
Installing backup lights and camera
Hi ive recently purchased a gently used 1991 25 ft execcla and im going to install led backup lights and a camera. Im wondering if anyone has any tips or pointers on this? Can I find the reverse wire on the rear of the trailer or do I need to run it from the front? The schematic shows it towards the rear but I have no idea where.
SpletKay06 is offline   Reply With Quote
Old 06-19-2016, 12:15 PM   #2
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Name:	ImageUploadedByAirstream Forums1466356272.382187.jpg
ID:	264758Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356295.962500.jpg
ID:	264759Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356328.508630.jpg
ID:	264760Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356381.252143.jpg
ID:	264761Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356436.029793.jpg
ID:	264762Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356468.879717.jpg
ID:	264763Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356494.108933.jpg
ID:	264764Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356534.212427.jpg
ID:	264765Click image for larger version
Name:	ImageUploadedByAirstream Forums1466356552.155076.jpg
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is online now   Reply With Quote
Old 06-19-2016, 12:46 PM   #3
Vantair
Vantair's Avatar
Same issue with our 2005 25 Intnl CCD. Read of another member creatively connecting one to the dump light to manually activate a backup light. This could allow use without needing to be TV connected and in reverse. Looked and bought other LED lamps but didn't like the non-factory look in placement.
Thanks to Amazon, found a sealed waterproof Kalwell brand 22.00. With 9" aluminum sheet 12.00 a few bends extended license plate bracket. Made small access hole below factory LP light hole and below lateral support stud to near rear hatch. Allowed access into the forward side storage courtesy light wiring. Cut in a small rocker switch (recessed/inset to prevent accidental activations) to separately control the BU light or for courtesy. Keeps it safe, fused, clean and on a 24/7 power to use anytime without TV connections. Works looked great and REALLY kicks out the lumens !
Vantair
Old 06-19-2016, 05:13 PM   #4
Vantair
Vantair's Avatar
Also, must add..... researched our factory wiring schematic. Pulled tail lights to explore (found none) and ultimately calling JC which said backup light and wiring "does not exist to rear ". In the end, think this was a better solution since we would be 1st spotting the back up process and therefore close to the switch.
Vantair
Old 06-19-2016, 05:20 PM   #5
1991 25' Excella
Stanfield , Oregon
After some digging I found mine does have backup lights but they weren't working. Ive now got them working, but there not very bright. Also the wiring goes up and over the AS which makes it hard for a low mount camera. Im going to run the wiring through the frame and mount the camera/lights in the rear bumper.
Old 06-19-2016, 05:24 PM   #6
Vantair
Vantair's Avatar
Nice. Guess different models may have and others not. Odd the wiring is missing in some.
Vantair
Backup Camera and Rear Sensors Jim Foster Audio, Video & TV 4 10-19-2015 12:01 AM
Installing inverter and battery backup inside bwilson1 Electrical - Systems, Generators, Batteries & Solar 1 04-01-2015 10:36 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
How do you remove the backup monitor and camera? 92landyacht Land Yacht/Legacy Motorhomes 16 06-23-2012 03:18 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 09:54 AM
