Old 10-20-2017, 03:42 PM   #1
funkill's Avatar
Tucson , AZ
Images: 27
incandescent to rv to led
I am usually a big fan of the Search function but am just not getting the info I (think I) need....
I bought a couple light fixtures that are for home/residential use with the intent of using in my trailer. I LOVE these fixtures. Thought I'd just use the regular RV lights in the fixtures. But I'd prefer to convert them to LED. Is there an adapter base that converts from residential incandescent to RV LED?
Am I making this more complicated than it needs to be?
Cheers
FunKee - and the Silver Olive
2006 F-150 Lariat QuadCrew
AIR 31804
WBCCI 10718
funkill is offline   Reply With Quote
Old 10-20-2017, 03:55 PM   #2
2007 22' International CCD
I don't know of a direct adapter, but if it is a residential fixture, you can easily rewire it to use 12 volt LED bulbs. Look at http://www.led4rv.com/ for inspiration. They have a wide range of stuff that you could easily adapt.
A picture of your fixture inside and out would help solve this...
My thinking would be to replace the residential socket with something more suited for RV bulbs, then putting an LED in that socket.
Old 10-20-2017, 03:57 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There are a number of different "residential" light bulbs. Are talking about a 40/60/100W "Edison Medium" base?
These days, the normal approach for RV's is to wire things up with 12V LED's. A residential system is set up for 120V bulbs. Running 120V lighting off of 12V via an inverter is not a real good idea.
So - what sort of fixture are we talking about?
Old 10-20-2017, 04:19 PM   #4
funkill's Avatar
Tucson , AZ
Images: 27
Of course I am at work without the details. But they have edison screw type bases, E26 - with 60W tubular bulbs. And I'm fully committed to rewiring as needed to use. Just not sure where to start.
They're vanity style lights from HD (discontinued - so I bought all 4 that they had left)
http://www.homedepot.com/p/Hampton-B...5142/204816695
Name:	vanity light.jpg
AIR 31804
WBCCI 10718
Old 10-20-2017, 04:26 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Ummm, yes you are making it very complicated.
If I recall correctly DC current requires stranded wire and AC solid core wiring due to voltage drop. HOWEVER, since you are converting to LED lamps this may not poise a problem BUT 120 volt LED's will not run off 12 volt. You would need to re wire to automotive standard bases for this to work.
Cheers
Tony
Old 10-20-2017, 04:33 PM   #6
Half a Rivet Short
2022 Interstate 24X
Hi
Since you are after an odd shape as well as a non standard base (for 12V bulbs) this will become a bit of a science project. The simple approach is probably to hand wire / hand mount LED strips into the fixtures. You will probably need three or four sided strips to get a reasonable "look" from the fixtures.
Old 10-20-2017, 04:35 PM   #7
funkill's Avatar
Tucson , AZ
Images: 27
Cheers
Tony
Ok - that's what I'll do! I would want to use them on battery power/12v.
Now to select the wire gauge and bases.....
Thank you.
AIR 31804
WBCCI 10718
Old 10-20-2017, 04:36 PM   #8
funkill's Avatar
Tucson , AZ
Images: 27
Hi
Was thinking about wrapping a rod with the led strips....
AIR 31804
WBCCI 10718
Old 10-20-2017, 04:37 PM   #9
Half a Rivet Short
2022 Interstate 24X
Thank you.
Hi
The type of wire is not the issue. Finding an appropriately sized / shaped / color temperature LED array is.
Old 10-20-2017, 04:47 PM   #10
funkill's Avatar
Tucson , AZ
Images: 27
Hi
Ok - I'll study this more over the weekend. Hoping I can just remove the edison base and wire in the LED array then.... after selecting size/shape/color... and then tearing it apart to improve selection.
AIR 31804
WBCCI 10718
Old 10-20-2017, 04:58 PM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Is this what you are looking for? http://www.m4products.com/xw-9w-5630...ung-5630-leds/
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 10-20-2017, 05:12 PM   #12
funkill's Avatar
Tucson , AZ
Images: 27
Bill
Wow - is it? I think it might work. Though I'm mechanically inclined, I am VERY electrically challenged. I don't know why I can't work this out.....
AIR 31804
WBCCI 10718
Old 10-20-2017, 06:41 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Hi
The OP was talking about refitting the fixture for 12V LED bulbs, but all of my lights run through an inverter. It isn’t such a bad idea in my view...
Old 10-21-2017, 07:53 AM   #14
Half a Rivet Short
2022 Interstate 24X
Hi
A typical LED light pulls a couple of watts. Run off of 12V 100% of the battery energy goes straight to the LED.
Turn on your inverter and it likely pulls a few amps doing nothing at all. The circuits inside need to power up. Is that 2A or 4A? Who knows, it varies between manufacturers and models. It also varies a bit between samples of the same model.
Net result is that you are putting twenty to forty watts into running the inverter and three or four watts into running the LED off of the inverter.
Yes it's a bit more complicated than this. A 120V LED bulb has a power converter in it. They rarely are very efficient. This or that 12V LED array may or may not be well matched to 12V. Lots of grubby details.
Old 10-21-2017, 08:19 AM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
Bill
If the bulb is internally wired for 12 volts DC and has a standard 120 volt base, you should be able to screw it into a 120 volt AC fixture and mount the fixture on a 12 volts system. An interesting approach not one that would pass UL. If someone put one of them in a 120 fixture, which is possible in a trailer, it might get exciting.
I think the add may be misleading in that they show a bulb with a standard base. I would question the base on the 12 volt version before ordering.
My first thought was to make the bulbs. Take a plastic tube that could be fitted into the fixture socket and wrap it with LED strips, very cheap compared to premade bulbs, and wire the strips directly to the switch. This would require some experimenting to get the brightness as you want. I replaced all the lights, 16 fixtures, in my 34fter for less than $15.
2004 Excursion 4x4
Old 10-21-2017, 09:13 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Hi
All fourteen lights in my trailer all together (except for the incandescent vanity mirror lights) draw about one amp @ 120 v AC or 120 watts. My refrigerator also runs off 120 volts, (draws one amp AC when the compressor is on), and typically my two group 27s will last about 20 hours on a full charge.
My TV keeps everything up while towing, i am in my fourth year using this setup. (We started with CFs changed to LEDs a couple years ago) It works well for us.
I haven’t really noticed an appreciable power drain from the inverter itself, but that might change when I change to the pure sine wave unit I just bought. If so I will adjust for this or trade the MSW back in.
I threw away the RV rulebook when I built the trailer, some things worked well, some things not so well, but the whole trailer inverter thing I am very happy with.
Old 10-21-2017, 09:23 AM   #17
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
To me, the smart move would be to find some lights I liked, and then trying to find the right bases to put in place of the 120V bases.
Old 10-21-2017, 09:59 AM   #18
funkill's Avatar
Tucson , AZ
Images: 27
I think this is what I’m shooting for. Thanks.
AIR 31804
WBCCI 10718
Old 10-21-2017, 02:25 PM   #19
White Bear Lake , Minnesota
Cheers
Tony
Stranded or solid has nothing to do with 110 volt or 12 volt. It has to do with the flexibility of the wire, whether it will remain intact under conditions of high speed and constant vibration. Site built homes don't vibrate or shake unless there is an earth quake. Therefore solid core wire works for years.
Automobiles, trucks and RVs vibrate, shake, twist and turn therefore stranded wire is called for.
I do not understand why solid wire is used in any circuit in RVs except that 120v hardware is designed to accommodate solid wire.
There are a number of bulbs on eBay that will easily solve your problem. It should not require any rewiring. Simply put in the correct bulb. Even changing to 12 volts would not require rewiring but just to move the circuit to a 12 volt source. Be sure that you don't connect a 12 volt circuit to a 120 volt circuit.
https://www.ebay.com/sch/i.html?_odk...bulbs&_sacat=0
Lyle
lyleapgmc is offline   Reply With Quote
Old 10-21-2017, 02:28 PM   #20
Check Walmart for bulbs that will work on 120V or on 12V. I believe I have seen them there.
replacing 1141 incandescent bulbs with LED Globie64 Lights - Interior & Exterior 28 07-20-2014 09:09 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
Marker lights: Incandescent or LED hampstead38 1965 - 1969 Overlander 9 10-07-2008 08:16 PM
Incandescent VS Fluorescent upallnight Electrical - Systems, Generators, Batteries & Solar 3 06-17-2004 07:57 PM
