09-25-2013, 06:32 AM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
I Smell Something Burning
I am on the road camping and got up this morning to read. Turned on the front overhead light using rotary switch. It wasn't long before I began to smell that acrid smell of burned electrical wires. Traced it to the rotary switch in the front light of our "78" Ambassador. Obviously I won't find a switch and am headed home tomorrow and can deal with it then. In the meantime am I safe leaving it off or should I cut the wiring and tape off the ends? Or do something else? Thanks!
Somewhere in the mountains of VA...
09-25-2013, 06:36 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
If you have electrical tape, tape all exposed wiring. Keep the switch shut off. Cutting the wires is okay, as long as you can remember which wire goes where. You're going to have to replace the wiring anyway, so cutting it off where the insulation is gone before taping can't hurt.
09-25-2013, 06:42 AM
Airstream - Other
Bosque Farms
, New Mexico
Ha! Reminds me of the rheostat switch in the MG for the inside lights. A few months after I bought it, I was driving to work, and burned-rubber smoke starts pouring out of the dashboard. It was raining, so I couldn't ventilate too well. I couldn't hardly see!
Bottom line: I replaced the rheostat with a simple toggle switch, and all's been well since then.
Lynn
ACI Big Red Number 21043
09-25-2013, 07:11 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I would remove the power wire from the switch as the switch could short out all the way possibly causing a fire or more damage. Better to be safe than sorry.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
09-25-2013, 07:26 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I would remove the fuse from that circuit and leave the switch as is while traveling.
Did the fuse blow? If it did not, I wonder why? Maybe there was no short, just a heat buildup from a worn contact point?
ODM has that switch in stock.
http://odmrv.com/catalog/index.php?m...bjmojm6p2273k2
Alan
09-25-2013, 08:14 AM
I just replaced a rotary switch
The new one lasted one day. I have a thread on my solution. I am done with the rotary switches. Your misfortune confirms my decision. thanks and sorry for your problem....glad it wasn't worse
09-25-2013, 08:02 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Problem Solved...Almost
Well I decided to just cut the wires (after disconnecting AC/battery), cap with wire cap, and wrap with electrical tape. Interestingly enough the fuse did not blow. Once I removed the rotary switch it was apparent why it shorted out. One of the terminal connections was loose. Bad contact point. Now the question is whether to replace the rotary switch with another one, try another style of switch (how will it fit), put in a Fantastic Fan (but I loose my lights)...
Thanks for the help!
Indiana, PA
TAC PA-5
WBCCI 4871
09-25-2013, 08:43 PM
Central
, Mississippi
Originally Posted by Roadrunner
Well I decided to ..., put in a Fantastic Fan (but I loose my lights)...
Indiana, PA
TAC PA-5
WBCCI 4871
Bob,
I did this exact thing and installed a single tube 12V fluorescent bulb fixture on each side of the Fantastic Fan.
09-25-2013, 10:59 PM
1977 31' Excella 500
West Sacramento
One of my rotary switches burned just like yours. I bought new ones from Inland RV and replaced the incandescent bulbs with LEDs. After 3 years all is working well. One day I may ditch the original fixtures and install recessed LEDs.
