Old 12-30-2009, 12:04 AM   #15
VIKING's Avatar
Boulder Creek , California
Here's my contribution. It was mounted on the end of the street-side overhead compartment, above the refer. The gas was tapped off of the branch of the gas line that goes to the refer with 1/8" copper. It came through the floor right next to the refer and ran up the wall to the overhead cabinet, alongside the refer shroud, then into the cabinet, and into the back of the light.
Rich the Viking
Name:	'64 SAFARI 039.jpg
VIKING is offline   Reply With Quote
Old 12-30-2009, 03:16 AM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by Ganglin View Post
Humphrey was bought out by Paulin. You can by lights similar to the originals and they have parts also. Link to main page and parts page below...
Gas Lights by Paulin, Humphrey and Falks
propaneproducts.com: Gas Lights - Parts & Mantles
I have yet to find a Paulin version of the light for sale, only the Mr Heater ones...
Aaron
WBCCI #XXXX AIR #2495
Old 12-30-2009, 03:19 AM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Originally Posted by vswingfield View Post
Where are the gas light usually mounted?
How are the propane lines run?
What kind of clearances must be maintained?
What kind of ventilation regimens must be observed?
And of course, post pictures!
Seriously. I have always heard about the gas lights in trailers, but have never actually seen one. I would appreciate pictures of installed gas lights and discussion of what those of you who added them did.
I have only seen them mounted on the forward facing bulkhead of the fridge compartment.
On the 70's vintage the line was run in the fridge compartment, I believe it tees off the fridge LP line under the trailer.
IIRC clearances to the ceiling needs to be 12" or so, side clearances are similar.
Ventilation? crack a window.
Aaron
Old 12-30-2009, 04:13 AM   #18
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Aaron
Try here:
PAULIN OUTDOOR PRODUCTS - INDOOR HEATERS
they all look similar - the vintage 70's style had a little longer body that hung down behind the globe (have one I got on Ebay that needs repainted and installed).
Old 12-30-2009, 05:42 AM   #19
Baltimore , Maryland
Lehman's the Amish super store has them.. Lamps & Lights*|*Gas Lighting*|*Gas Lights*|*Paulin/Humphrey Gas Light Parts - Lehmans.com
Old 12-30-2009, 06:04 AM   #20
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Looked at the Lehman site and also Cabella's where I bought my last batch of mantles. Price seemed high for the soft mantles. Could be more than 1 in a pack but did not say.
Here is another source, less than a buck a piece
Paulin, Humphrey, Falks Preformed - Tie Mantles
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 12-30-2009, 06:22 AM   #21
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
In the barn
I might have a couple green lights in my barn... $10 a piece!
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 12-30-2009, 06:33 AM   #22
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Magic Lamp
Although my original gas lamp isn't a Humphrey, it gets use on every trip. Its a Veritas brand made in Germany and similar versions are still available. I've only needed to change the mantle once and I've been on all kinds of roads. Have only used the modern Coleman mantles and have great luck with them. The gas line runs up the streetside wardrobe closet and T's off the stove line and then runs up across inside the overhead galley locker directly to the lamp.
Love the lamp and use it often.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-30-2009, 06:48 AM   #23
Wise Elder
Jammer's Avatar
2010 30' Classic
Mine says 3" side clearance and 4" top clearance, and 2000 BTU/h, on the approval sticker. Humphery recommended 3/8" copper tubing.
They burn gas at a rate comparable to a stove burner on "low" and I consider the basic draftiness of any house or trailer to be sufficient ventilation.
Old 12-30-2009, 06:53 AM   #24
Wise Elder
Jammer's Avatar
2010 30' Classic
The clip-on mantles work well and are much more convenient to install and remove.
Old 12-30-2009, 08:27 AM   #25
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Originally Posted by 62overlander View Post
They have the parts not the lamps. FWIW I have tried to purchase the Humphrey/Paulin lamp, but everytime I have tried they come back as NLA or out of stock. The ONLY substitute that I have been able to buy is the Mr Heater version. I suspect that those are copies of the Humphrey/Paulin being made in China versus the Canadian made one. The two I do have are Humphrey.
Aaron
Old 12-30-2009, 08:46 AM   #26
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
FF
That is SO cool! I want one of those!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 12-30-2009, 09:02 AM   #27
robandzoe's Avatar
Plymouth , New York
Yeah they are!
They are pretty cool... I've got the same light as Brad - I prefer the Veritas over the Humphrey anyday!
Plymouth, NY 13832
Courtesy parking
Old 12-30-2009, 09:51 AM   #28
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Well, last time I did a search they were available but doesn't look like it anymore. My old link is dead. These do come up on Ebay occasionally and are not inexpensive.
Same here Rob, anyday!!
FF
greg gibson, vintage-airstream.com
Humphrey Gas Mantles ColtSAA45 General Interior Topics 3 03-21-2004 02:05 PM
