Old 05-16-2016, 02:40 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
how to find a short
I pulled three marker lights to replace them with Led's.
I installed 1 LED assuming the wire I tested for zero OHM was the ground.
When I put a spade fuse in the plug it blew. I tested the marker light terminal on the plug and it is grounded somewhere (not inside the plug , I checked).
Can a more precise OHM reading tell me which of the marker light wires is the culprit. (since I have to assume upon removing one of the three lights, I must have pulled on the positive wire and grounded it)
I already tried to push the wires back in as far as I could to see if that might remedy the problem. And the lights worked just fine before I pulled the three marker lights.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-16-2016, 02:57 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
With power completely off the circuit, measure ohms between each positive light wire and ground (the shell should do for a ground). The one that doesn't read infinity is the culprit. You can stick a sewing pin through the wire if you need a place to connect the ohm meter and don't want to strip insulation.
Good luck.
Enjoyed meeting you at the Johnson City rally.
Old 05-16-2016, 05:30 PM   #3
Airstream Driver
1997 30' Excella
Images: 51
Good luck.
Thanks for the input. They all read infinite with all the power off.
1996 Airstream B190
AIR #13
Old 05-18-2016, 05:09 AM   #4
Airstream Driver
1997 30' Excella
Images: 51
Rivet solved
I failed to remember that the tail lights were in that circuit as well.
Even after removing all the marker lights, I still had zero resistance on all the marker light wires due to the incandescent bulbs in the tail lights..
1996 Airstream B190
AIR #13
Old 05-18-2016, 05:23 AM   #5
1966 22' Safari
Weatherford , Texas
Did you find the short?
Old 05-18-2016, 05:33 AM   #6
Airstream Driver
1997 30' Excella
Images: 51
I wrongly assumed there was a short due to the incandescent bulbs in the circuit. The initial fuse blowing was caused by me reversing the wiring of the first LED, I installed.
1996 Airstream B190
AIR #13
Old 05-18-2016, 05:34 AM   #7
1966 22' Safari
Weatherford , Texas
That'll do it. Glad you found the problem.
Any idea where I can find a short 30A cord for generator use? barrettjl Electrical - Systems, Generators, Batteries & Solar 18 11-01-2012 12:02 AM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Can't find a short! KAMPOTA s Lights - Interior & Exterior 12 03-14-2010 06:35 PM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
