Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-22-2008, 10:32 AM   #1
1973 31' Sovereign
Charleston , South Carolina
how to fasten tail light assembly '73 Soverign
i can see rivets that were broken off i think, but i would like to know how to fasten properly.
thanks.
jim.
cuyd is offline   Reply With Quote
Old 06-22-2008, 11:32 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
A standard aluminum rivet (aluminum shaft also) and a dab of Parbond or Alcoa Gutter Seal on the head of each. Seal the top and side edges of the assembly with the same. Enjoy...
Old 06-22-2008, 12:06 PM   #3
thanks.
jim.
Someone has spliced a portion of a quarter panel over the original panel.
Your tail light assembly was fastened to the quarter panel, with pop rivets, from the inside of the sheetmetal, when the trailer was manufactured.
Instead of removing the quarter panel, or tearing out the inside of the trailer to get at the tail light, you can reinstall it by adding some vulkem, to the back side of the bezel, then fastening the bezel to the metal with some plated sheet metal screws. When the vulkem cures out, it will help to hold the bezel in place.
Unfortunately, the screws will have to stay in place.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-22-2008, 01:08 PM   #4
1973 31' Sovereign
ok
thanks: ganglin & andy
here is some more photos
so far i have only drilled out rivets (belly pan, banana wrap, inside panels etc., i have not started to put anything back together.
andy everything looks original doesn't look like a splice to quarter panel over the original panel.
there is a portion of broken rivet attached to rear of bezel but you dint see any rivet on the finished side, dumb question, but i thought rivet goes all the way thru quarter panel & bezel to work?
thanks.
Jim.
ID:	62687   Click image for larger version
ID:	62689   Click image for larger version
Replacement Tail Light Lense Assembly Swanny Lights - Interior & Exterior 5 07-02-2015 11:30 PM
How to Fasten Underlayment to Subfloor AStreamJake Floor Finishes 4 09-17-2014 05:32 PM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
Need '77 Argosy Motorhome Tail Light Assembly Panel adamstarr Lights - Interior & Exterior 1 09-29-2006 01:58 PM
Tail light assembly needed. AccessMaster Airstream Motorhome Forums 6 08-05-2003 07:35 AM
