02-05-2017, 07:44 AM
#21
2005 30' Classic S/O
2003 34' Classic
Madison
, Alabama
Re: My Fluorescent to LED Conversion Update
Al,
Thanks, The conversion looks nice. It's great to see the results. I still haven't finished my research on what bulbs to use. I may use the LED strips I already have to do one fixture. Those are the Utilitech ones. I think if I put all four strips in one fixture, that would provide a useful light output for some of the lesser used fixtures. I've seen some very bright high effeciency units online which would be nice, but they are pricey.
BRN 1221, S/OS #024, KK4PF
2016 Silverado K2500
02-05-2017, 08:15 AM
#22
2002 30' Classic S/O
Fleming Island
Originally Posted by stanp001
Al,
Stan,
In my first post, I identified the strip I used. A 5m strip, more than enough for my 8 fixtures, was less than $16. I don't think you need high efficiency LEDs, just more of them per foot. Mine were about 7 lumens per LED IIRC.
Your signature says S/OS #014. I thought you were #024?
Al
02-05-2017, 02:22 PM
#23
2003 34' Classic
Madison
, Alabama
Originally Posted by Al and Missy
Stan,
Al
Al,
you are correct about S/OS number. I've fixed my signature. Regarding the LEDs. I was more thinking of trying to reduce the energy consumption for boondocking. The lighting and cost for your lights is excellent.
Stan
02-05-2017, 03:20 PM
#24
2008 25' Classic
Full Time
I converted the lights in my 2008 Classic 25fb to LED including the flourescent lights.
http://www.airforums.com/forums/f366...fb-124369.html
Kelvin
02-05-2017, 07:47 PM
#25
2003 34' Classic
Madison
, Alabama
Originally Posted by KJRitchie
Kelvin,
The lights in the first of the videos in the link to your post are the same ones I have, so it is helpful to see how the conversion is done.
Stan
02-13-2017, 09:38 AM
#26
Fleming Island
Al,
Stan
You won't get much bang for your buck going from regular LEDs to Hi-efficiency, I don't think, but I could be wrong. In fact there is not a lot of efficiency improvement replacing the fluorescents with LEDs. The fluorescents burn substantially less power than an equivalent output incandescent.
I did it because the inexpensive fluorescent bulbs I bought to replace all of mine started going out after a year and only about 60 nights on the trailer. Assuming we ran the bathroom light for an hour a day, the bulbs were starting to go at only 60 hours. And the starter seemed to be voltage sensitive. If the batteries got even slightly low, some bulbs wouldn't light.
Al
02-20-2017, 08:23 PM
#27
2022 25' Flying Cloud
NCR
, Ontario
LED also come in Warm and cool colours
Warm is like normal bulb and on the yellow side
Cool is more white and like a cleaner white than fluorescent
Sometimes you can find and middle colour called daylight or natural, its colour is between the two. check the colours at your local home centre. in our house , we use both colours depending on the function of the room. warm is nice in the kitchen but cool is better to read by at a table
02-20-2017, 08:27 PM
#28
NCR
, Ontario
check out lee valley http://www.leevalley.ca
they sell LED on adhesive strips on a spool with low , medium and high density of LED.
that is the high density has the LED closer together and more intense light
be sure to test what you want to install. you dont want too much light or too little
02-20-2017, 08:44 PM
#29
FlamingoRoadTrip
2007 34' Classic S/O
Livingston
I found the Utilitech strips on Amazon for $9.35 for a pack of 2. It pays to shop around!
Mark and Jane
FlamingoRoadTrip
2007 Classic Limited 34 with Slide
2015 Ram 3500 with Cummins 6.7 Diesel
02-23-2017, 03:37 PM
#30
NCR
, Ontario
hello
this is what I used in the sport 22 and home kitchen
The exceptionally versatile tape lights are available with warm or natural white LEDs in three light densities, or with red, green and blue (RGB) LEDs in two light densities to produce a near-endless array of colors.
there different types with warm or natural white LEDs
30 White LEDs per metre (9 LEDs per foot)
60 White LEDs per metre (18 LEDs per foot)
120 White LEDs per metre (36 LEDs per foot)
see here what they look like
http://www.leevalley.com/en/hardware...,70322&p=70323
03-02-2017, 05:16 AM
#31
2003 34' Classic
Madison
, Alabama
Al
Al,
I have experienced the low voltage issue with the fluorescents. Been on the road for several weeks, but will get back on the LED project when I get back.
03-02-2017, 05:21 AM
#32
2003 34' Classic
Madison
, Alabama
I was recently at Alumaflamingo and saw one of the new Airstream's which had LED strip lights mounted under the lip of the Awning near where the awning attaches to the trailer. Has anyone done this mod? I thought it was a nice effect
